Edge Comp - random, intermittent malfunction..
Old Jun 20, 2003 | 04:39 PM
KatDiesel's Avatar
Re:Edge Comp - random, intermittent malfunction..
Its the box, this is a common problem that surfaced with a certain batch of boxes produced. Get it replaced from Edge. It IS the only solution, and yes its ALWAYS corrected the problem since it is within the box itself. No installation error, no loose connections, just a problem with the box itself.
Old Jun 20, 2003 | 08:02 PM
TPilaske's Avatar
My Comp was doing the exact same thing about a month or so ago and I got it replaced. Just give them a call, they'll get a new one out pronto! ;D<br><br><br>Tony
Old Jun 20, 2003 | 09:21 PM
KatDiesel's Avatar
[quote author=Gary - KJ6Q link=board=7;threadid=16146;start=0#151642 date=1056147030]
HMMmmm - I've Emailed Edge as well, and will see what they suggest - I would hope that they would offer some sort of exchange program - I'd sure hate to have to UNinstall the Comp, and then wait a couple of weeks for all the exchange to be completed - then have to reinstall it - yeah, i know it's only a few plugs, but still a pain, and tight quarters and hard plugs to get loose... And I'm pretty sure you can't simply unplug the box and still operate the truck without all sorts of codes being set...
[/quote]
They will suggest the same as I just posted. There is no way around it. Why would you have to uninstall the COMP? Unplug it at the back of the box, reconnect the MAP sensor correctly and unplug the data link connector and away you go. Leave the harness in the truck, should take 5 minutes tops. It will take a week or so for the turn around depending on when you ship it out (day of the week).
Old Jun 20, 2003 | 09:35 PM
phox_mulder's Avatar
Or, if you live where I do, just drive on up, maybe 45 minutes away during rush hour.<br>Disconnect it, take it in, get the new one, reconnect and your home in another 30 (better comp, better speed ;D )<br><br>I just wish they sold direct, without all the distributor markup.<br><br><br>phox
Old Jun 21, 2003 | 10:17 AM
BigBlue's Avatar
Mine did the exact same thing. I called Edge and they said to ship it back to 'em. Shipped it back. As soon as they got it, they called me and said they were going to ship me a brand new one at no cost. No questions asked. Mine was under warranty though. I don't know bout yours. Knock on wood, I haven't had any trouble since. ;D
Old Jun 21, 2003 | 11:30 AM
AlpineRAM's Avatar
Gary: You could ask for the update to drag comp when you ship it ;D this should make the wait worht while <br><br>AlpineRAM
Old Jun 21, 2003 | 12:26 PM
BigBlue's Avatar
That costs an extra $125-$200. Don't remember exact price. I had my old Comp for about a year when it started acting up also.
Old Jun 21, 2003 | 12:32 PM
KatDiesel's Avatar
[quote author=Gary - KJ6Q link=board=7;threadid=16146;start=0#151725 date=1056162940]<br>Those connectors weren't all that easy to get to and connect the FIRST time on my truck, and I'm not real anxious to repeat it... Plus, screwing around with connections tends to introduce still more variables and potential problems - I've read of a few guys who had Edge send them exchange replacements - may not be their standard policy, but I'd have no problems simply giving them a credit card # for security, and then canceling it when they receive my exchange unit - otherwise, I'd probably just let the truck stand until the exchange was done and a new unit in place...<br><br>We'll see what happens - I carefully went over all the plugs to make sure none had worked loose - just in case that's a contributing factor - can't call Edge until Monday anyway...<br>[/quote]<br><br>Yes I have known Edge to ship first so the truck isn't down but I am unsure if they still work under that policy? Thats why I didn't mention it. <br>As far as the connections, your paranoid, on the MAP simply connect it into itself on the harness to protect it and the data link would be easily cleaned upon reinstallation, don't mess with the wire tap. If you consider those connections &quot;hard&quot; then I dunno what to tell you.
Old Jun 21, 2003 | 12:37 PM
KatDiesel's Avatar
[quote author=Gary - KJ6Q link=board=7;threadid=16146;start=0#151842 date=1056212598]<br>HMMmmm - seems to be a fairly common failure... <br><br>Wonder what it is that fails so often, yet apparently is so easily identified and corrected... Also wonder if any significant operating upgrades have been made since I bought mine...<br><br>Mine's almost a year old - got it right after I got the truck middle of last year - Edge seems to have a good reputation for service - but *I* also have a tight realtionship with &quot;Murphy&quot;, and if anything CAN go wrong, it most likely WILL! ;D ;D<br>[/quote]<br><br>I've already posted there was a bad batch of boxes (not sure if its hardware or softeware related can't remember) thats why it is easily identified, and a known problem. Its fixed no questions asked regardless how old the box is generally.<br><br>Unplug the box, and look on the back plate. Is there a sticker? And if so what does it say.<br><br>Keep in mind I have been dealing with Edge since May of 2000 back when Brett first contacted me.....so yes I have some experience with their products.
