Removing calipers
Old Nov 27, 2006 | 10:35 PM
steerjock's Avatar
Removing calipers
My brother is changing brakes on his truck and is having trouble figuring out how to remove the caliper, any hints or links to a website to help? Any help is appreciated.
Old Nov 28, 2006 | 12:29 AM
CowboyDave's Avatar
A large "C clamp". Open the valve after the pressure has been achived with th C clamp and then proceed to tighten C clamp
Old Nov 28, 2006 | 06:11 AM
CUM4X4MINS's Avatar
He needs help on Removale CowboyDave
No help here sorry TTT for ya!
Michael
Old Nov 28, 2006 | 12:30 PM
djgaston's Avatar
Take out the two 18mm bolts and pull up on the caliper? I don't know if the rear calipers use the same size bolt but I know the fronts are 18mm. Make sure you use threadlocker when putting them back in.
Old Nov 28, 2006 | 01:53 PM
HappyGA's Avatar
and do not open the valve when pressing the pistons back in, so a little at a time without opening the vlave, and you will not have to bleed them afterwards. Takes about two minutes total per side to compress the caliper pistons like this...SAves you the headache of bleeding..
Old Nov 28, 2006 | 05:12 PM
steerjock's Avatar
Yeah we figured that out when we put brakes on my truck plus our dad told us we should of done it that way after we were done bleeding them.
Old Nov 28, 2006 | 06:15 PM
CowboyDave's Avatar
I had a braking problem pushing the fluid back in one time, I was told to never do it again. So........I havent.
Old Nov 29, 2006 | 08:40 AM
GMScott's Avatar
Take the reservoir cap off before pushing the pistons back in!!
sjessop
Jan 18, 2010 03:40 PM
Palmetto_kid
Dec 15, 2004 06:07 PM
Hawkeye 04
Oct 10, 2004 12:18 AM
DZLPWR
Mar 22, 2004 10:34 AM
AZGEARPRO
Mar 15, 2004 11:44 AM
