Removing front calipers - 91 350 4wd
Old Jan 18, 2010 | 02:00 PM
sjessop's Avatar
I've got the truck half out of the garage, front end up in the air and I'm trying to chang the front pads. I can't get the EDIT caliper retainer out. I've got the big Bendix brakes, and according to my manual, that retainer should just slide out. I don't see any other bolts that look like they are holding it in place. Any help will be much appreciated.
thanks
stu...
Old Jan 18, 2010 | 02:19 PM
Load Hauler 04's Avatar
The retainer won't just slip out like the manual says, it takes a 4 lb hammer and a punch/blunt chisel . It will go either direction. It may be froze so soak it with wd-40 then try it..
Old Jan 18, 2010 | 03:40 PM
grouch's Avatar
thanks
stu...
If the bolts are clear, I'll bet the last person to work on it didn't use the proper grease on the retainer. You need to get a DBH (darn big hammer) and a steel drift and poke it out. When you reassemble it, make sure to put a little bit of caliper grease on the sliding pin. DON'T get it on the pads for obvious reasons. Also, watch your thumb when you're wailing away. Don't ask me how I know that.
pengyou
Cummins Conversions
Mar 5, 2009 06:20 PM
steerjock
Nov 29, 2006 08:40 AM
jriggs_18
Aug 25, 2006 12:20 AM
rob-dude
Nov 17, 2005 04:28 PM
Palmetto_kid
Dec 15, 2004 06:07 PM
