Remote Starter System
Old May 26, 2007 | 09:53 PM
Wv7o's Avatar
Originally Posted by donhov
Also if starting and letting idle for more than a few minutes remember that if the tranny isn't in neutral, not park, that you can damage the front pump bearings as the pump does not work in park, just neutral on the auto trannys wiithout modifications to the valve body.
So on my 06 auto letting it idle in park is not good for the trans?
Old May 27, 2007 | 03:32 PM
timcasbolt's Avatar
Don't know about the pump thing, never heard of that before, but I'm positive you could let your truck idle for a LOT longer than a few minutes without damage of any kind. Letting the engine idle for hours at a time would not be good for the engine, but damaging the transmission is highly unlikely.
Old May 27, 2007 | 05:27 PM
donhov's Avatar
Do a search on the subject, look for 48 RE and long idle times in park or ask your Dodge dealers transmission specialist, if he is knowledgable if not ask an independent transmission shop. For years the Dodge tranny is set up so that it does not pump fluid when in park, (don't know about the new 07 68RE) but all prior trannys do not pump when in park, thats why to check the transmission level your owners manual says in neutral, not park. Do not let your truck idle in park for long periods of time, anything longer than 5 minutes or so is considered long, put it in neutral and use the emergancy brake if you need to let it idle.
Old May 29, 2007 | 06:27 AM
saskpuller's Avatar
Putting a sentry key in the column is an old school not to mention lazy way of installing a remote start. The newest alarm/immobilizer bypass kits use data. No Key required.
Old May 29, 2007 | 11:58 AM
PG4x4's Avatar
Hmm I didn't know that about the idle thing. Up here in the winter it can get to -30 and I don't even turn my truck off till I'm done with it at the end of the day.
I priced out a car starter/alarm and they wanted $1000 install for one here. But he said it was top of the line and would start and tell u if someone was breaking in from a mile away.
Undertaker
Oct 26, 2009 03:02 PM
Mopar_Mudder
17
Jan 25, 2004 08:32 PM
moosetooth
Apr 4, 2003 06:56 AM
Ruadh
20
Nov 10, 2002 10:00 PM
