Rapid Blinkers w/Brakes on????
Old Apr 14, 2008 | 03:42 PM
langloisandy's Avatar
All,
Howdy....help needed. I had a bulb out warning light on, off to AutoZone for bulbs, I replaced the bulb (correct one, 3057?), weird behaviour now:
Left Blinker Works BUT goes to Rapid Blinking when Brake is applied, it goes away when the brake is let off.
Any thoughts on what might cause this?????
Thanks much,
Andy
Old Apr 14, 2008 | 03:45 PM
ptgarcia's Avatar
Brake light out maybe?
Old Apr 14, 2008 | 03:51 PM
Light out..nope
Hi, thanks for the fast response.
Lights work fine, its the blinker that goes FAST when the brakes are applied. This one is bizarre, even for me!
Andy
Old Apr 14, 2008 | 03:53 PM
turbos10's Avatar
Andy
Alot of times wierd stuff like this can be a loose or broken ground connection......and sometimes hard to find.
carbuff415's Avatar
I would double check the ground wire(s).
Old Apr 14, 2008 | 03:54 PM
Ground
Let me go poke around, THANKS!
Old Apr 14, 2008 | 04:13 PM
cwrhnr's Avatar
I had the same problem with a trailer attached one time, it was a bad ground wire on it. Hope it helps
Old Apr 14, 2008 | 04:16 PM
Ryan Hyatt's Avatar
i have the same problem on my 06 mega tell me if it works or what is wrong. thanks
Old Apr 18, 2008 | 06:22 AM
Fod Nazi's Avatar
Check the blinker module.. probably internally shorted. On my old Chevy, it was under the dash, left side, buy the fuse box. It's a small plastic box. They were about $10 at Auto Zone. Get the Heavy Duty rather than the Normal Duty if you're towing...it has a better load capacity. If that's not it, check for a grounding wire.
Old Apr 18, 2008 | 08:16 AM
Dodgezilla's Avatar
You probably have another one of the taillight bulbs getting ready to burn out.
Old Apr 26, 2008 | 04:51 PM
Found it
All,
Well I searched, searched and searched more, looked at fuses, relays, switches, traced wires, lost my mind, tracked wires, looked at diagrams, swapped out bulbs, lost more of my mind. The lights would work while parked, then after a few miles start to blink rapidly, not work, nothing normal. Weird.
FINALLY, I just wired tied the Left Side pig tail to the light assembly. THIS FIXED IT! Apparently the plug backed out JUST enough to let the lights act weird, not work, act weird again and drive me CRAZY!
Anyway...thanks for all the tips!
Andy
bradshaw106
Dec 12, 2009 07:35 PM
Valv
Oct 21, 2007 07:10 PM
shemp47
0
Nov 15, 2004 01:42 PM
pancowboy
Feb 11, 2004 07:31 PM
