Radio Power on key-accessory?
Hello;
Still learning the ins/outs of my new-to-me 2003 Dodge Ram 2500 CTD.
Something I noticed yesterday was that the radio does not have power when I turn the key to "accessory". Just to be clear, I'm talking about when you rotate the key backwards towards you. My cigar lighter port gets power when I do this, but nothing on the radio.
Every other vehicle I have even had did not do this. I always had power to the radio with the key turned to accessory in every vehicle I have ever owned.
Is this normal for my truck? Or, is the radio supposed to have power when the key is in this position?
It is a factory radio; appears to be original. AM/FM/CD, non-infinity.
I'm eventually going to swap it out for a double-din unit and add a backup camera; but that is for another thread....
Thanks for any and all replies.
--Matt
--Matt
Thanks to you both for the replies.
I just got a copy of the FSM for my truck, I'll see what it says about radio operation.
Mike67RS --- please let me know how you like this setup you are going to install. Any chance for sharing pictures? A camera in the tailgate handle wired to a new double-din radio is exactly what I want (someday). I'm curious where you run the wires into the tailgate so they won't get pinched when moving the tailgate up/down
UPDATE:
Just looked this up in the factory service manual (FSM) page 8A-1. "The audio system uses an ignition switched source of battery current so that the system will only operate when the ignition switch is in the RUN or ACCESSORY positions"
I'll check the fuses, but since the radio works otherwise, I'll bet it's not a fuse.
The radio has issues, several lights don't work; it's possible some problem internal in the radio. Also possible something wrong somewhere in the wiring or the ignition switch itself. Whenever I take the radio out I'll check for voltage at all the correct pins.
The dealer I just bought this from pulled the dash out to fix the HVAC doors before I bought the truck. They might not have plugged everything back in all the way or missed a ground somewhere.
My truck with the OE radio for a few years used to work with the key in the accessory position. Then occasionally it would not work, no matter what I did to the key. Eventually it got progressively worse to the point that it would not work at all, although i discovered by accident that if the drivers door was open that the radio would work in the accessory position. That makes no sense, but just reporting my experience. Many years later the OE CD player died, so turfed that radio and installed a cheap after market radio that works just fine. Connected it to a keyed wire that I knew worked when the key was in the accessory position.
ironbrew
Apr 4, 2014 10:35 AM
danimal 95
Nov 17, 2011 02:13 PM
Crankpot
Jan 19, 2009 04:45 PM
gyman98
Jul 21, 2007 12:06 PM
...Ben
