Radiator flush
How often do you guys flush your Rad? Is it something that worth doing your self or would you just take it and have it done?
I drain the radiator and clean out the overflow bottle once a year. Then I refill the system with a mix of Zerex G05 Hoat coolant and distilled water. This way I am replenishing my coolant additives on a constant basis,therfore eliminating the need to flush the system entirely.
Originally Posted by Dr.Dizzle
(Post 2584371)
How do you drain the system? And how much comes out?
Originally Posted by elirandolph
(Post 2584397)
Did you have to remove the bottle to clean it out or is there a plug on the bottom?
Originally Posted by bansh-eman
(Post 2584435)
How do you get the rest of the system drained? What does the draincock run you to replace?
(Post 2584488)
By replace the draincock, I meant to put it back in and snug it up. I have never purchased a new one. I probably should have one as a spare, since it is made of plastic with o rings to make a seal. [duhhh] |
Hummm... Looks like I may have to do this soon. I got an 06 with 42k so I don't think it has been long enough to start rusting. At least I hope not.
How many bottles of Zerex G05 Hoat coolant do you need? |
(Post 2584683)
How many bottles of Zerex G05 Hoat coolant do you need? I do a simple radiator drain and refill every year to keep the fluid fresh. What came out the first time really surprised me, sand that I'm assuming was from the head and block castings. I'm glad I didn't wait the recommended 5 year interval per the manual. Be advised, the Zerex coolant is not the pink/orange color like the factory coolant. It is a gold /clear color which is almost transparent. The factory coolant is just Zerex dyed to Dodge specifications. The partial drain and fill should eliminate the need to ever flush it,especially doing it every year or so. On average,I would think the fluid would be fresher than doing a flush every 5 years. I believe that the entire cooling system holds a total of 7.75 gallons. |
I assume I can pick it up at Walmart?
If I drain the rad, and want to fill it back up, do I need to buy 8 jugs? I don't want to do Distilled water because I may be moving and don't want to chance it freezing. |
(Post 2584824)
Walmart does not carry it. If you have a Napa close by, they use part# ZXG051. If not, you can try your local Ford dealer. They carry GO-5 at a decent price, last time I checked. And of course,you can also try your local Dodge dealer. If I drain the rad, and want to fill it back up, do I need to buy 8 jugs? I don't want to do Distilled water because I may be moving and don't want to chance it freezing. |
Great thanks. I got a Napa right down the road... Now just got to see if they got it in stock.
You know what you pay for it? |
(Post 2584902)
You know what you pay for it? No problem. Happy to help. From the NAPA website in store shopping page: NAPA Item#: ZRXZXG05RU1 Price: $7.77 tax and shipping not included Disclaimer: The stated price may vary from the in store price and may change at anytime. Attributes: Size:1 GAL Product Features:Factory Fill & Approved For Ford & Daimler Chrysler Vehicles Phosphate Free Reduced Silicate Fully Formulated Manufacturer:Valvoline Application:Zerex G-05 - Ready To Use - Liquid - Yellow |
Good information--thank you. Have you changed the thermostat, water pump or hoses?
Jay |
