Question on door panel removal
Old Jan 27, 2010 | 01:16 AM
eot's Avatar
eot
Hey guys I am thinking of changing out my front door speakers on my 06. I have not pulled the panels off this truck any helpfull sugestions. or special tricks?
Old Jan 27, 2010 | 05:24 AM
sabersix's Avatar
Panels come off pretty easy. As I recall, there are two screws at the bottom of the panel and two bolts. One holding the door handle and the other up by the mirror. Remove all and then lift up as there are plastic tabs on the back of the panel that hook into the door metal.
The water barrier is stuck to the metal door with some sort of black tar goo. If you carefully pull back the barrier while cutting the black goo with a razor, you can stick it back on after your done.
Old Jan 27, 2010 | 09:10 AM
cbrahs's Avatar
front doors- 2 screws (large) one behind the lever, one on a-pillar
2 screws at very bottom of door
1 bolt- door handle 10mm and you don't have to remove the entire bolt. just remove enough for the handle to come off so you don't lose the bolt in the door panel.
rear doors- 2 screws on bottom of door
1 screw behind door handle
after you get these removed, pull UP (towards top of door) and then out. You can disconnect the window/lock controls from behind.
Had all 4 of mine off last night installing jimmy jammers
Old Jan 27, 2010 | 11:05 PM
eot's Avatar
eot
Thanks guys just did not want any suprises with plastic clips breaking like they did on my 01. Hey what is jimmy jammers??? Thats a new one on me.
Old Jan 28, 2010 | 12:40 PM
ssandlin's Avatar
Take a look here
http://www.jimmijammer.com/
Old Jan 28, 2010 | 12:45 PM
pdogg's Avatar
those jimmi jammers are to keep the idiots out of your truck.... pros go right thru the lock...
ask me how I know...
Old Jan 28, 2010 | 12:46 PM
bansh-eman's Avatar
I would buy the Jimmie Jammers while you have everything off. I installed them on mine a few years ago. Very ez install. I also have the Gate Keeper as well.
Old Jan 28, 2010 | 02:24 PM
cbrahs's Avatar
just another layer of protection but like said above, pro's go thru the lock.
D45
Nov 11, 2014 09:56 AM
PRO-NRA
Feb 10, 2008 10:04 AM
LockedandLoaded
Feb 8, 2008 06:14 AM
mp_tx
Dec 15, 2006 12:03 PM
SkyHarborCowboy
Feb 13, 2006 07:46 PM
