Poor seat heaters... need circuit diagram
Old Jan 11, 2005 | 09:28 PM
eastmentCTD600's Avatar
Hello all,
does anyone have the wiring diagram for the seat heaters handy. I'd like to see if I can modify the heater output, but i need the diagram.
Thanks,
Old Jan 11, 2005 | 10:40 PM
Jeff in TD's Avatar
Looking at the diagram, I suspect the control module would go into fault mode if you changed anything in the temp probe...
I have the paper manual, so I can't send the diagram.
Old Jan 12, 2005 | 04:53 PM
How so? I'm just lookin to fool the module which recieves input from the temp sensor. Just need to know where all the circuitry is so i can cetermine if it's worth the trouble. I figure a 10 - 15% increase in output would be nice.
Thanks anyway!
Old Jan 12, 2005 | 10:53 PM
Jeff in TD's Avatar
Well, it looks like pin 3 on the control module is the passenger heat sensor input, and pin 5 is driver's side.
Tan/dark blue and tan/lt blue respectively.
The control module is apparently pretty complex. Input from the switches is resister multiplexed, and it apparently self diagnoses bad input from temp sensors or open circuit or short with heaters...
It shows High light off and low light flashing to indicate temp sensor out of range.
It apparently supplies 5v to one side of the sensor and monitors voltage on the other side.
I can't find where it says how many ohms should normally be there... I suppose a person could take a reading, then jump in a resister and see what happens.
Let me know if you get something to work. I'd like mine to be warmer, too.
Hopefully there is someone in your neck of the woods that can let you look at the manual.
Old Jan 13, 2005 | 12:15 PM
RonsRig's Avatar
Here is a link to the wiring diagrams for the 2004/2005 model years. It will want you to download a .zip file that contains the diagram.
http://www.dodge.com/bodybuilder/
bhoeffner
Jan 18, 2013 09:00 PM
cougar
Nov 1, 2009 09:23 AM
AkitaSumo
50
May 1, 2009 07:38 AM
Joe Diesel
Nov 12, 2007 08:59 AM
PADZZ
May 24, 2003 09:57 AM
