Over load spring contact points
Overload spring contact points
I've noticed on my 07' when I pull my 5th wheel trailer (approx 3500lbs pin) that the rear end squats a bit, not terrible but not level.
My old 99' would handle the same pin wieght and sit perfectly level and that truck didn't even have the upper overload spring setup.
I'm thinking of adding extensions to the bump stops of the overload setup so that they take up the load sooner and hopefully get the truck to sit level with the 5th wheel attached. The overloads just touch when the truck is at rest.
Has anyone done this yet????
I just added some Timbrens a couple of week ago. I'm far from being a mechanic but thought I would give it a try took about 45 min for the install. They work really well . My truck would ride on the overloads when hooked to my 4H gooseneck LQ.
Mike
Mike
Brian
That's exactly what I'm thinking of doing. Then all I need is a nice set of ladder bars to get rid of the terrible driveline wind up that these 3rd gen trucks have. I think it must be worse on manual trucks as opposed to auto.
Thanks guys for the comments.
On my previous truck, a Ford F350, I installed air bags. The truck sat on the overload spring when hooked to my 5th wheel. They worked great and leveled the truck out. The biggest advantage it absorbed some of the road vibration transmitted from the axle to the frame.
I haven't decided if I need them or not on my 3500. The overload springs touch the stops but not too bad and the truck looks level when hooked up.
I build a spacer 1 1/2" high that fit the contour of the top of the bump pad.
Works great with the camper on but I do get some "slapping" of the overloads while empty on rough roads-washboard and such.
Looks to me like that could just unbolt with one bolt or even a wing-nut and you could install it only when you pull the trailer. Might even take less time to slip that thing in and install the nut than some guy's spend to air up their air bags. I bought a set of 3500 overload springs for my 2500 and am going to make a nice adjustable mount for my stops with a standard hitch pin to locate it where it won't touch for daily drives but I can move it down a hole to pull with. I can do this cause I don't have the factory mounts on my frame rail for the overloads and need to make some anyway. But they will look something like the ones pictured in the other reply made out of some 2" thick wall tube for the "slider" and some hitch reciever tube for the frame mount. I also made a very heavy duty custom tow bar the same way. I made 2 "recievers" that took place of my factory tow hooks with a removable mount for my tow bar so it doesn't have to hang there all the time. I have made a few of them for guy's that have seen it and wanted one for themselves. Its a very heavy duty setup that is longer than most tow bars you buy. Pulls great and you can turn around on a dime with it hooked up. I also ran a wire harness the length of my truck and a tail-light bar so the truck in tow has lights. Used it many times towing those FEMA units down south.
2-Stroke
Jul 12, 2010 06:35 PM
shoffs30
Jul 6, 2008 08:57 PM
carwash
Sep 12, 2007 11:39 AM
