Nitto Terra Grapplers LT305/55/20
Old Mar 6, 2006 | 12:18 AM
barn6720's Avatar
Question--like to put mentioned tires on unmodified (i.e. no lift) 03 2500 4x4. I believe the consensus from trying to research many forums is that they should fit. What do you say? Will they fit? Any problems? Rubbing? Binding? Also, I'm trying to confirm but don't see the info on Nitto's website- are these tires 10 ply/E? The wheels I'm looking at are 20x10, 8x6.5, -18mm offset and 4.75" backspacing.
I must preserve the ability to safely tow my fiver but do it while looking good!
Thanks!
Old Mar 6, 2006 | 07:58 PM
TopBanana's Avatar
yes the tires are E load range. and they should fit on the truck without rubbing.
although the rim width and backspacing is critical when it comes to fitting or not. some 10 inch wide rims make the tire rub against the control arms at full turn.
Old Mar 6, 2006 | 08:07 PM
RCCOX's Avatar
I just put the same combo on my truck last week.They will rub on a stock truck.I installed a 2 inch leveling kit and still had to trim a little off my inner fender.I t was a little work but it sure does look good.
Old Mar 6, 2006 | 11:08 PM
barn6720's Avatar
Thanks for the replies! I appreciate the help!
Old Mar 7, 2006 | 12:56 AM
island8's Avatar
I have that set-up with a 4 inch lift and it rubs at full turn.
Old Mar 7, 2006 | 08:52 PM
dplenzig's Avatar
I have Toyo AT 305/55/20s with a leveling kit and the don't rub at all.
Daren
Old Mar 7, 2006 | 10:40 PM
daniel's Avatar
well this is a little off subject but i wouldnt buy those tires i had them on a truck and i thought they gripped good but punctered to easily i had 3 plugs in a month or so and i was only driving on pavement just something small would puntion them.
Old Mar 8, 2006 | 10:09 PM
Luken's Avatar
I have em, I really like how they grip and the wear is awesome. Everytime I check they look and feel the same as the last time. Mine will rub when Im turning into a parking lot with a dip or steep incline. Also when its full turned in reverse. Its not rubbing on the control arms, just the lower (inside) of the bumper. I am going to order a leveling kit, if that doesnt fix it then Ill trim it.
I see no problem with towing your 5er with them....
CTDowerTN
Sep 11, 2006 01:27 PM
ajb1974
Apr 12, 2006 07:32 AM
Brock
14
Feb 25, 2006 12:11 PM
Brock
Feb 19, 2006 12:25 PM
Strjock81
13
Oct 22, 2004 07:06 PM
