Need a valve stem kit for DRW so I can fill & check
Old Apr 7, 2009 | 07:07 PM
CACalomino's Avatar
Took the truck in to the dealer to fix the white smoke on start up and to see if they could extend the valve stems or what ever they have to to do so I can check and add air to the rear wheels since the stems r on the inside.
Dealer said they have nothing and cant get anything so are there any kits out there to fix my problem?
-Chris
Old Apr 7, 2009 | 07:12 PM
Patriot1's Avatar
yes there are and they will bolt to the floater axles bolts and if you spend a little extra you can get the one with a gauge on it.
Old Apr 7, 2009 | 07:37 PM
scottsjeeprolet's Avatar
The problem with those are that if one tire gets a leak both will go flat.
Just buy the adapter for your compressor so you can fill your tires. I find it easier to just pull one wheel off the truck to adjust the pressures. My hand won't fit in the window easily.
Old Apr 7, 2009 | 08:49 PM
aborgardt's Avatar
geno's has them but they are not cheap.....I got them for my truck and love them.
Old Apr 7, 2009 | 10:22 PM
CACalomino's Avatar
What are they called exactly? Gona look them up on there sight. Have any pics of what they looked like. So basicly I can adjust both tire pressures at once sounds cool ill have to look into them.
-chris
Old Apr 8, 2009 | 06:23 AM
aborgardt's Avatar
They are made by airplus. Here is a link
http://www.genosgarage.com/products.asp?dept=82
They are not to join the 2 tires, as stated before that is not wise, it is only to bring the valve stems to the outside for access without removing the wheel.
Old Apr 8, 2009 | 08:58 AM
Jeff in TD's Avatar
I was thinking I'd get some of those, but I want to get some metal valve stems first.
Someone also makes a U shaped valve stem to make things easier, but that would make it tough to rotate tires.
Old Apr 8, 2009 | 06:53 PM
aborgardt's Avatar
genos sells a set for the inner tire and a set for the outer tire. the come off just like a cap so they are not hard to move from tire to tire when rotating.....the outer tire is a u shape.
Old Apr 8, 2009 | 09:17 PM
92'1stGen's Avatar
I bought one of these and it works great.
http://www.northerntool.com/webapp/w...70_48541_48541
Old Apr 9, 2009 | 10:42 AM
darkvader's Avatar
look up dual dynamics, crossfire. ran them on my big trucks and now on the dualy. excellent. some les schwab have them but you have to tell them what psi you want or they will cheerfully sell you 100psi set as they don't know what they are doing(suprise)
Clark
Old Apr 9, 2009 | 02:30 PM
shep1's Avatar
I think Camping World has several types , maby in their catolog.
Old Apr 9, 2009 | 07:55 PM
johnh's Avatar
i had a set that were extension hoses and brackets that screwed to the hub caps. worked pretty good until i did the conversion
Old Apr 10, 2009 | 06:50 AM
MikeyB's Avatar
I use the same tool for our duallies.
MikeyB
Old Apr 10, 2009 | 04:47 PM
carl48's Avatar
mikeyb has the best idea. just use the steel valve stems the others mentioned will eventually cause a low tire failure on our 06's where we change pressure depending on load we find a tool carried by napa that is a combo rubber mallet and a pry bar specifically for the removal of the hub cap is very helpful
Original Junior
16
Aug 8, 2006 09:06 AM
Kampnnut
Jun 21, 2006 12:48 AM
Rocky in KC
Mar 5, 2005 08:39 AM
Tartarus
Jan 19, 2004 10:03 AM
Mopar_Mudder
Jul 16, 2003 09:10 PM
