lowered dually
Old Oct 19, 2008 | 03:35 AM
noribilt's Avatar
lowered dually
Has anyone here lowered a dually? I had bought my truck to put it to work, but I don't use it for much just cruise. I am really thinking of putting 22s or 24s and slamming it. I saw a 05 dually online and looked very cool.
Old Oct 19, 2008 | 04:10 PM
TriSum's Avatar
It all depends what setup you are talking about. 22" big rig style or 22" low pro style. Is your truck 2wd or 4x4 ?
I run 19.5's on mine. I lowered the rear with a Kelderman kit so it sits level. I wouldn't mind taking another inch out of the front, but being 2wd it already sits pretty close to the factory bump stop on the front arm.
David
Old Oct 19, 2008 | 08:22 PM
beardedone's Avatar
I did. I have an 08 dually stock but wanted to lower it a bit because of clearance for my fifth wheel. I only moved two spaces as that was the minimum I needed and I was afraid if I moved them all the change in attitude might bother the drive train. Same procedure everyone was using, like on my 04 2500
Old Oct 19, 2008 | 08:38 PM
txfiremedic's Avatar
Here's one from another member on here, can't remember his username though:
Old Oct 19, 2008 | 08:47 PM
belgianmagic's Avatar
are you saying "you took out two "SPACERS"? I want to lower my back end but didn't know if it could be done...
Old Oct 19, 2008 | 09:50 PM
beardedone's Avatar
Yes, you can move the spacers to the opposite side of axle. I only wanted to move two of them so I asked the dealer to do it before I picked the truck up. For me it makes a big difference because it gives me a little more space between the top of box and underside of the fiver. This was done exactly the same way on my 08 dually as it was on my 04.5 2500. I have 17,000 km on it and a lot of heavy towing and it has worked fine. This is the same procedure that was used widely a few years ago and I think it was posted on this site, complete with pictures.
Old Nov 12, 2009 | 02:36 PM
Im thinking "THAT LOOKS SAH~WEET !!
Old Nov 12, 2009 | 03:40 PM
FiverBob's Avatar
Put Bremen boards on it and it will look lowered without the problems, especially if you are towing.
Bob
Old Nov 12, 2009 | 10:34 PM
8mpg's Avatar
Airbagit.com has a 4 or 6" axle flip kit.
kantdrive55
Jun 3, 2009 06:26 PM
NYTCTD
May 31, 2008 10:40 PM
OFFDUTYEXPEDITOR
Jun 15, 2005 01:32 PM
faster_than_ford
Jan 28, 2005 08:57 AM
