Line-X on rocker panels
Old Apr 19, 2006 | 12:13 PM
  #31
Festus's Avatar
There is one problem I foresee with black diamond plate or chrome......rust. Just something to consider. This is why I like the sprayed idea. It seals out moisture. Have mine on my '98 for 8 years now - no rust.
Old Apr 19, 2006 | 12:44 PM
  #32
Sgt. Peper's Avatar
Just double click the photo and it looks good!
Old Apr 19, 2006 | 12:46 PM
  #33
Sgt. Peper's Avatar
Habor Fraight does it around here as cheap as anyone!
Old Apr 19, 2006 | 07:01 PM
  #34
Dragginbutt's Avatar
Looks good Sumner.. something I have been keeping in the back of my mind for when I have a little pocket change....
Old Apr 19, 2006 | 08:09 PM
  #35
CtdinBC's Avatar
I have an 05 that is already showing rust in a few spots (lots of salt on the roads around here) I am wondering if linex on the rockers would stop this rust, or would it continue to rust behind the coating, with no way to treat it?
Old Apr 19, 2006 | 08:22 PM
  #36
shopboss's Avatar
we've probably sprayed a dozen or so rockers on trucks, (i own a line-x dealership), and i'd have to say the best looking one was an all yellow S-10, really is sharp, i should have taken some pictures. on the rust issue, if whoever does it cleans up the rust good and spots it with some self-etching primer it will be fine, spraying over it with line-x or any quality product will take the oxygen away from the rust and kill it, as long as it's not at a seam where air and moisture can get at it from behind. still wont prevent it rusting from the inside out, which is usually the case.
Old Apr 20, 2006 | 10:59 AM
  #37
PWT05Dodge's Avatar
Does anyone when the Line-X xtra is supposed to be available in colormatch formulas? An old post said the beginning of 2006, but I haven't heard anything about it. Thanks!!
Old Apr 20, 2006 | 06:16 PM
  #38
Vortex does colors.... When looking for rust, make sure teh drain plugs remain open. I suspect you are getting water inside too... You need to give it a way to drain out... or all your money will go down the drain so to speak...
Common
Aug 26, 2006 04:25 PM
rudy
Jul 5, 2006 07:30 PM
GlennRMK
21
Jun 18, 2005 01:14 PM
MedicShawn
Feb 26, 2004 11:21 PM
debolton
20
Dec 14, 2002 08:30 PM
