leveling springs to high
Old Sep 22, 2015 | 05:08 PM
hrdwoodbbq's Avatar
Installed leveling springs today now the front of the truck is 1" higher than the rear. Anyone know how much if any i can expect the springs to settle?
The other possibility is that the rear leafs have flattened out a lot from new. Anyone know the distance from the center of the rear axle to the fender?
Old Sep 22, 2015 | 05:28 PM
Danderson's Avatar
A signature would help us help you. I use Don Thuren's HD adjustable rear shackles to dial in the proper leaf spring height.
Thuren - Shackles - Strapt Performance.com
Old Sep 22, 2015 | 07:24 PM
hrdwoodbbq's Avatar
Working on getting my signature to show up. Until then 2004.5 4x4 short box ext cab 35x12.5 x17 bf Goodrich T/A KO 2 tires
Old Sep 22, 2015 | 09:20 PM
Danderson's Avatar
'Ya got it!
Old Sep 23, 2015 | 09:37 AM
hrdwoodbbq's Avatar
As a quick cheap fix could I add a 1/2 spacer between the leafs and the axle. Looks simple and easy anything I am overlooking?
Old Oct 28, 2015 | 11:34 AM
DragonSlayer's Avatar
I have the HD coils for my 3500 2wd, been on for over 25,000 miles and are awesome. I little stiffer than the original springs, but they are considerably larger in diameter. I couldn't do the Sumos because my right spring was almost 3" lower than the left.
Old Oct 28, 2015 | 12:44 PM
jeephauler's Avatar
I went the same route after installing the Carli kit which left the front sitting what appeared to be high. I have the Thurens installed in the highest setting and the truck sits perfect now.
Old Oct 30, 2015 | 10:57 AM
soulezoo's Avatar
DTR 1st Sergeant
To answer the original question... no; do not expect to see any settling of the front springs to make up the difference.
Jordan5687
Jan 29, 2015 10:32 AM
Dan70
Mar 5, 2014 04:10 PM
53 willys
23
May 19, 2008 06:14 PM
95turbo4wd
Dec 12, 2007 05:59 PM
bigred496
Oct 22, 2004 07:16 PM
