Lamp Out??? Help
Old Aug 25, 2010 | 07:45 PM
JonnysDodge's Avatar
Lamp Out??? Help
So I looked in the owners manual, and it doesn't give a whole lot of info on it. The headlights, tail lights and turn signals all work great. Also the Break lights all work good as well. Any suggestions on why the Lamp Out indicator light keeps coming on and then going off while driving? Thanks in advance
Old Aug 25, 2010 | 08:16 PM
DiezelSmoke's Avatar
My guess is a bulb filament. When the indicator light comes on pull over and check the lights. Or change one bulb and see if it stays out, if it doesn't move the bulb to another, repeat as needed til you find the bulb. Or take each bulb out and tap lightly and see if the filament moves inside. Also you don't have a 7 to 4 pin trailer adapter in the truck?
Old Aug 25, 2010 | 08:19 PM
A buddy has my 7 to 4 pin adapter. So it could be that as well then, the plug is pretty dirty.
Old Aug 25, 2010 | 10:00 PM
Kowalski's Avatar
Pull the bulbs and look closely at the wire on the bulb that runs over the plastic on the base to make contact to the socket. Chances are you will find one or more of the wires have melted into the base of the bulb. Also check the socket board for corrosion aswell.
Old Aug 25, 2010 | 10:16 PM
madhat's Avatar
Administrator/Jarhead
I have found that this is a problem quite often.
Also, don't forget about the third brake light.
Old Aug 26, 2010 | 09:59 AM
Thanks for the help found the problem pretty easy on the drivers side tail light. Thanks for the advice. This is why I love this forum.
Old Aug 27, 2010 | 09:58 PM
Tejasdge's Avatar
From: Texan living in the eastern settlement known as Georgia
This can drive you nuts. I had to replace the bulb holder/panel to fix a months long intermitent chime and idiot light. Glad you found it.
Hoss
21
Dec 3, 2016 02:49 PM
bullrider9800
19
Aug 25, 2008 08:14 PM
ShawnQ
14
Jun 5, 2007 01:17 PM
Pickle
Mar 26, 2005 11:57 PM
