Just a little help
Just a little help
Hey guys would really appreciate the help. I have a 2003 2500 5.9. Bought a bully dog GT, download went through all the way but no start. Uninstall went through all the way no start. Called bully dog went through the recovery with no problem still no start. I've tried resetting by touching the negative and positive together with batteries unhooked. Checked all fuse, and checked that all power was going where it needed from ignition to starter. When I turn the key on still have battery and fuel gauge and the bully dog still reads coolant temp and air temp. Fuel pump kicks on , turn the key and nothing, no click, just nothing. Hoping it's not an ecm but have a feeling that's what you guys are going to say. Just wanted to make sure there wasn't something I was missing before I hit the dealer
Also I'm only throwing one code p2123. Thanks again for any and all help for a new guy to the forum. Read a lot of threads for the last two days and couldn't find one that fit
p2123 is Throttle position sensor, I am not an expert here , but have heard somewhere that it could be related to your cruise controle. If your TPS is bad you may be able to find more info and sensor here....
Timbo APPS
Timbo APPS
When you say no start the engine turns over but doesn't light off?
When you turn the ignition key to the ON position do you hear a ticking noise from under the hood? That's the number one injector firing to help prime/purge the lines. If it's not firing I would be concerned that's its the ECM.
As a sanity check unplug and replug both ECM connectors to the module.
I would look at any keyless entry or alarm setup if you have it on the truck. My wifes Dodge Caliber did that years ago. It would not turn over but appeared to have strong battery. I simply unplugged the battery for a few minutes and back on and it started, Dodge ended up replacing a module under warrnaty that had something to do with the keyless entry. The range for locking the doors was cut down after that. I suppose it also could be the starter. Something loose or it has a bad spot that it stopped on.
47
47
thenrie
07-23-2010 11:10 PM
