how to romove cup holder
Old Mar 11, 2006 | 09:54 AM
kully560's Avatar
looking to put a guage inbetween my heated seat switchs and can not figure out how to remove cup holder to get behind dash
Old Mar 11, 2006 | 10:25 AM
FMB's Avatar
FMB
I know what I have
I know how to remove my cup holder, but then again, I know what vehicle I'm working on too. Please fill out your signiture with what you have and it will pop up all the time.
Old Mar 11, 2006 | 10:52 AM
kully560's Avatar
I have a 2003 quad cab 4x4
Old Mar 11, 2006 | 11:47 AM
tonyiii1's Avatar
To take out seat heater buttons, you take off the dash panel, not the cup holder. There is one screw behind the garbage hook and the rest are clips that will release when you pull on the dash piece. Disconnect all wire clips on dash piece (very easy, they can't get mixed up because they are all different) then you can work with the area you are talking about very easily. Just did it two days ago.
Old Mar 11, 2006 | 11:58 AM
FMB's Avatar
FMB
If its a Laramie with an HO and 6sp, use a trim stick and pry up the transmission shifter boot from the console, remover the inserts, remove the 3 bolts that hold it to the floor, then lift it up on the back and remove it.
If it isn't an HO and 6sp, try this after you disable the airbags;
(1) Remove the center bezel
...(A) Disconnect and isolate the negative battery cable.
...(B) Open the ashtray and cup holder.
...(C) Remove the one center bezel retaining screw
...(D) Using a trim stick C-4755 or equivalent, gently pry the center bezel free from the instrument panel.
...(E) Working behind the center bezel, disconnect all electrical connectors and remove the bezel.
(2) Remove the airbag control module trim cover.
(3) Open the cupholder and fold down the inner panel.
(4) Remove the two inner screws.
(5) Remove the remaining four screws and remove the cup holder.
rsgstr
Dec 14, 2003 02:49 AM
richard
Jul 27, 2003 10:01 PM
Cumminsdude
May 16, 2003 04:17 PM
scottrod
Mar 31, 2003 07:39 AM
