headlights
Old Oct 15, 2006 | 10:32 AM
siver19's Avatar
headlights
Has anybody had a problem with their lights turning on and off by themselves while driving. I believe thats what is happening, but it could also be switching between hi and low beams.
Old Oct 17, 2006 | 05:28 PM
03whitedually's Avatar
Do they flash and then turn off completely after being on for a little while? if so it may be your headligt switch going out
Old Oct 17, 2006 | 07:42 PM
siver19's Avatar
No, they just flash on and off. But end up being on. But now itsalmost like they are switching between daytime running lights and normal lights. But I know they dont have running lights.
Old Oct 17, 2006 | 09:19 PM
adkl1's Avatar
i did a few months ago. happened a few times 06 3500 ctd
Old Oct 18, 2006 | 12:53 AM
BigDave12768's Avatar
I know the town cars would flash when the headlight switch was going. Ask the dealer or the parts guy. They usually know right away
Old Oct 18, 2006 | 02:50 PM
Stock 99 CTD's Avatar
Read the post last night before I went to bed. When I got in my truck this morning to head to work I noticed my lights were getting dim then bright. I thought "what the heck". Pulled back into the driveway so the lights would shine on the garage door so I could tell for sure. Sure enough they would get a little bit dimmer and then brighter. Interestingly enough when I would rev the motor they would get brighter. Had to go to work, once I got out on the highway they were fine. Got to work pulled the truck in the shop and they were fine. Will check in the morning and see if the condition happens again.
Old Oct 18, 2006 | 03:00 PM
mattk50's Avatar
its probably just your grid heater cycling.probably nothing to worry about.
Old Oct 18, 2006 | 03:09 PM
XLR8R's Avatar
Exactly - won't happen when it's warm out.
Old Oct 18, 2006 | 03:44 PM
BlackSunShyne's Avatar
+1. Yup mine does the same, nothing to worry with.
Old Oct 18, 2006 | 04:39 PM
siver19's Avatar
Thanks for the replies
Old Oct 19, 2006 | 12:14 PM
You are probably correct. It was about 20 degrees warmer this morning than yesterday morning and the lights did not change any. Will check the next cold morning.
Good Call. Thanks.
Extreme Diesel
40
Dec 25, 2006 11:23 PM
Hunter
13
Dec 20, 2002 05:59 AM
kingofdodge7131
Dec 14, 2002 02:43 AM
24
Dec 2, 2002 08:19 AM
