head light switch
Old Oct 29, 2003 | 08:34 PM
frank's Avatar
head light switch
has anyone had a problum with the light switch. my lights don;t always go off when the switch is turned off. dosn;t do it all the time , anyone else ever had this happen and what was the fix. i am thinking change the switch--
Old Oct 29, 2003 | 08:36 PM
phox_mulder's Avatar
Re:head light switch
[quote author=frank link=board=17;threadid=21713;start=0#msg203355 date=1067481262]
[/quote]
If it's the same switch Dodge has been using for years, then yes.
They've been problematic since day one.
phox
Old Oct 29, 2003 | 09:01 PM
RamDan03's Avatar
This may not be your problem, but if you try to turn off your lights after you shut off the engine, they won't go off unless you flip the switch back to the parking lights and then off again. Our 3rd gen trucks have an automatic light shutoff feature which will turn them off by themselves in about 60 seconds. I turn my lights off before shutting off the engine so I don't run into this issue.
Old Oct 30, 2003 | 06:01 AM
t6_man's Avatar
[quote author=RamDan03 link=board=17;threadid=21713;start=0#msg203374 date=1067482901]
[/quote]
Ditto on this. Not all trucks have this feature, but some do. I'm not sure what the criteria is for including this feature, but I'm sure it depends on the trim line. The first time my headlights stayed on, then went off about a minute later I ran to my owner's manual and researched it. That's when I found out about the delayed light feature (page 84 in the '03 manual). Bottom line is, turn your lights off first, they are out; turn your engine off first, the lights will stay on for 1 minute. This stay-on time is adjustable to several other intervals too (30 or 90 seconds), in case you want to use this feature, but not for 60 seconds. You can also have it programmed for a delay of '0' seconds, which I guess eliminates the delay. The dealer has to perform the programming. :-[
Old Oct 30, 2003 | 05:08 PM
mymaur's Avatar
Yep, read your owners manual. Operating as it should.
Old Oct 30, 2003 | 06:27 PM
frank's Avatar
did what you guys said and it works. didn,t know it had that .thanks---frank
Old Oct 30, 2003 | 06:28 PM
cby52's Avatar
The cargo lamp also has a timeout feature, although I haven't tried it yet.
Old Oct 31, 2003 | 04:30 PM
gadgets's Avatar
Hey, thanks for the info - my lights would stay on too, & I thought something was wrong!!
Good to know it's a 'feature'...
Rene
Old Oct 31, 2003 | 05:24 PM
spots's Avatar
Hey didja notice that the indicator for the signals in the cab flash at a different rate than the actual lamps outside??
Old Oct 31, 2003 | 06:34 PM
eswartz's Avatar
Speaking of signals, I don't know if the majority of the people here in Missouri even know they have signals, if they do they certainly don't use them.
BTW - I just noticed last night the signals flashed opposite the dash indicator. Only had the truck a month, just haven't done much night driving.
Old Oct 31, 2003 | 08:10 PM
gadgets's Avatar
Spots-
YES; just didn't remember to write a comment til I saw yours!
Rene
smokeyram
Aug 21, 2009 06:19 PM
redramnc
Mar 28, 2005 06:58 AM
INJECTOR JACK
Jan 21, 2005 09:43 AM
Pureliving
Nov 12, 2003 08:53 AM
hekroh
Nov 2, 2003 01:30 AM
