head light switch
head light switch
A guy I work with has a 95 2500. It burned the connector off the back of the headlight switch.
Does any body have a diagram to wire in a relay to take the load off of the switch
On a 94, you wire the relay into the B/Y wire, I believe. It controls the parking and running lights.
In my experience, the problem comes from the rheostat overheating from running with the dash lights dimmed down. I did relays, heavier wiring, and so on with no real luck.
The Summit kit is part# SUM-890030. It puts a relay on each headlight removing load on the switch. Also gives brighter headlights because they are running directly from batt through relays. Summit phone is 800-230-3030.
redramnc
Mar 28, 2005 06:58 AM
