FIX for Annoying steering Rattle 03-08 PICS
Old Dec 3, 2008 | 06:10 PM
chadder1313's Avatar
Flaming River? Got any links?
Old Dec 3, 2008 | 06:52 PM
Matt400's Avatar
http://www.flamingriver.com/index.cfm
Old May 15, 2014 | 02:30 PM
highrpms's Avatar
Update
I know this is an older thread and I just tired this. I am 99% sure it has nothing to do with cleaning the spline? It has everything to do with re-tightening the two bolts. I could see visible wear marks in the u-joint in the cab. It appears tight since it has lock-tight on the threads, but in reality the shaft wears down the u-joint a little. After tightening it the clunk went away. I did pull the shaft, but before you do try tightening them down.
Old Nov 13, 2014 | 09:21 AM
Vanellies's Avatar
slip yoke?
What do you mean by the "slip Yoke"?
Originally Posted by Matt400
If your talking about the slip yoke then cleaning the lube out of the splines would not be good IMO.
With one end mounted to the cab and the other mounted to the frame there has to be some movement there. The clunk sound and feel in the wheel is probably a lack of lubricant as the splines can "stick" and then let go causing the clunk/pop.
GM has had big troubles with this, I haven't heard of it on Dodge.
mstep3
Oct 25, 2010 12:26 AM
snoyes
Jan 8, 2009 11:35 PM
Brendan
Mar 27, 2007 09:33 AM
Patrick Campbell
Sep 10, 2005 05:12 PM
