Emergency brake sticking.
Anyone had trouble with the e-brake sticking? My wife had trouble yesterday after backing out of the garage. Temp was about -4c.. brake was locked and she could not get up the hill in front of the house ... Had 8" of snow and truck was in 4x4...Told her to try backing up and if that didn't work push as hard as possible and try to release. Eventually brake released and ABS light came on. It reset after about 3 miles of driving. Seems ok now. Any had similar?
Haven't had the problem yet with my CTD, but my 98 F-150 would do that when the temp dropped below freezing. I have a large puddle on my gravel drive, so it is easy to splash water up into the brakes just before I get home and park it. If I apply the e-brake and then it freezes, I am dragging a rear wheel until it breaks free.
If you look where you pedals are, you will see where the E-brake cable enters a tube. Check to make sure you have greese in there. Also follow it out, i am pretty sure there is a zerk fitting to put more greese in there.
If the cable is getting h2o in it you may want to see if you can warranty a new one.
We got about 7 inches of snow the other day and I had to flip it in 4x4 to get back to the trailer. When I flipped it back into two the brake stuck. I just turned truck off and back on and it hasn't done it since. That was the only time by the way.
