drilling the frame
Old Feb 19, 2008 | 03:16 PM
mostly stock's Avatar
drilling the frame
I thought i read somewhere that you are not suppose to drill holes in the frame, but not sure where i read it, something to do with how they are made.
Is it or is not alright to drill holes in the frame? (eg. to mount a fuel pump)
Old Feb 19, 2008 | 03:58 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
sides of the frame ok, top and bottom flange, not ok.
Old Feb 19, 2008 | 04:16 PM
snoyes's Avatar
Lot of discussion a while back about the new frames of the Dodge's and how you where not supposed to drill them. However, I know there was only 1 case where drilling the frame caused frame failure (on a flatbed install). I cannot remember the specific circumstances...
Old Feb 19, 2008 | 07:50 PM
so what is it about the frame,
materials?
way it is formed?
why the sides and not the top and bottom?
thanks for the answers...
Old Feb 19, 2008 | 07:56 PM
snoyes's Avatar
It was based on the hydroformed frames. While stronger than the older frames, they do not do as well with holes drilled in them. Hopefully an engineer will chime in here!!
Old Feb 19, 2008 | 08:35 PM
bob4x4's Avatar
Read through this site it should help fill in the blanks
http://www.dodge.com/bodybuilder/
Bob
Old Feb 19, 2008 | 11:14 PM
Equalizer 2's Avatar
A small hole or two drilled for mounting a fuel pump will not damage the frame according to the info I have from the installation instructions for my 5er hitch. They cite a Dodge Engineering Bulletin, the information I have is below.
Very important to use a spacer if you are bolting "through" the frame as with my receiver hitch.
Dodge Full Size – 2003 Thru 2004
(Figure 15-16)
Note: These instructions require the use of bracket kit # P-110. The chassis on these
vehicles is a full-length box tube chassis. Based upon information received from the vehicle
manufacturer, (Dodge Truck Engineering Bulletin No. 021),
the following procedures meet
Dodge requirements for installation. Be sure to observe the following:
1) Holes are not to be drilled in the top or bottom of the frame rails. Holes to mount brackets
must be drilled in the web (vertical sides) of the frame rail with the following restrictions:
a) Hole diameter should not exceed 20mm (0.75 in.).
b) Material between edge of hole and top or bottom of frame rail must not be less than 40mm
(1.60 in.).
c) The minimum edge distance between any two (2) holes must be larger than twice the
diameter of the larger hole.
d) All holes should be drilled in the frame using appropriate drilling practice and safety
precautions.
e) Avoid drilling holes near the fuel tank, fuel and brake lines and other lines and wires to avoid
damage to them.
Old Feb 20, 2008 | 09:49 PM
thanks for the 411
KRB
Mar 26, 2010 09:56 AM
ptgarcia
Sep 12, 2006 06:04 PM
Ramtough
May 3, 2005 08:06 AM
Patrick Campbell
Feb 20, 2005 10:35 AM
AK RAM
Oct 15, 2004 11:18 AM
