drain plugs
Old Dec 8, 2005 | 07:15 PM
bluepp's Avatar
drain plugs
Which is best from GENOS --The ( Finger Touch ) drain valve,--- or the ( EZ Change Drain Plug )
Seems to me the Finger Touch could get bumped open by a stone or snow ETC??????????
Old Dec 8, 2005 | 07:36 PM
TexasCTD's Avatar
I got the fumotovalve from Genos. It takes two actions or movements to open it and let it drain. It is spring loaded so it won't open unless you push and then turn the handle.
It sure is nice not having a 12 quarts of oil dump out into the drain pan like Niagara Falls. Plus it makes it easy to get an oil sample if you are sending one in for some reason.
Old Dec 8, 2005 | 08:57 PM
DirtEater's Avatar
I just got my first Geno's order on door step today. I got the Fumoto Valve with nipple (oops, that may get censored) and I have to admit, I was skeptical of it before I got to hold it. It doesn't seem likely at all that it might come open accidentally. It's a quality made valve. I'll take it to Home Depot to find a good fitting rubber hose to fit it for ease of draining.
Old Dec 9, 2005 | 08:58 AM
Mountainmac's Avatar
Got my Fumoto Finger Touch from Geno's as well. For added piece of mind only I just put a fuel line hose clamp on the Fumoto making it impossible to open unless I hit a huge boulder which happens to hit the valve perfectly and the valve bends or breaks enough to let the oil come out
Life is better than ever now that draining the oil is sooooooooo easy
Old Dec 9, 2005 | 10:38 AM
cheff's Avatar
I went with the Ez-change because the fumoto valve looked liked it hung to low. I take the truck in some rocky places, the ez-change does not hang to much lower than a stock drain plug.
They are both excellent products.
Old Dec 9, 2005 | 11:17 AM
05mxdiesel's Avatar
fumoto drain valve from genos here as well. put it on after first oil change. no mess and now all of our vehicle have them. No need for a drain pan either, drain it into one gallon jugs.
Old Dec 9, 2005 | 05:51 PM
irish4u's Avatar
I went with the magnetic drain plug,(also from genos) because I like the idea of picking up the metal. But now I`m considering a valve because I would like some control of the oil flow, geeez can it be a messy job. Is there a way to have both? Magnet and valve.
Old Dec 11, 2005 | 05:22 PM
alMout's Avatar
I got the fumoto drain valve directly from Fumoto, shipping is a lot cheaper if that is all you are purchasing.
RyeThomas
34
Oct 13, 2008 10:47 AM
sdaly
Apr 28, 2005 07:19 AM
rjweiss
87
May 27, 2004 04:56 PM
tlea7
16
Feb 4, 2003 04:48 PM
beavercreek
Dec 23, 2002 04:28 PM
