quick change oil drain plugs
Old Jan 28, 2003 | 02:09 PM
tlea7's Avatar
Anybody using these? They sure look convienent,but are they reliable? I.m looking at the 2 differeny ones Geno's sells.<br>Tim
Old Jan 28, 2003 | 02:34 PM
Commatoze's Avatar
Re:quick change oil drain plugs
I use the EZ-Drain from Geno's. It works great. I used the ball valve lever (or fingertouch) model years ago, and while very nice, it took forever to drain, and the &quot;streamers&quot; towards the end of the drain got blown all over the concrete driveway with the slightest breeze. The hose with the EZ-Drain can be directed right into a bucket and I often leave mine drain overnight without worry of messing the drive. I just have to leave a note over the wheel. &quot;DO NOT START!&quot; : ... ;D
Tom Hybiske
Old Jan 28, 2003 | 03:19 PM
Fishin2Deep4U's Avatar
I use the same as Commatoze. Works great!!<br><br>Dave
Old Jan 28, 2003 | 11:06 PM
sixpack47's Avatar
I also have the EZ Drain. ;D However I'm just waiting for my next oil change to install it! 8)
Old Jan 28, 2003 | 11:23 PM
Bart Timothy's Avatar
I use the &quot;fingertouch&quot; from Geno's and like it. It should be modified in order to drain all the oil out of the bottom of the pan, which is part of the reason why there are &quot;streamers&quot; at the end of the drain time.
Old Jan 28, 2003 | 11:32 PM
oldred97's Avatar
How much oil do these things leave in the bottom of the pan?
Old Jan 29, 2003 | 01:59 AM
Big Bob's Avatar
I have the Finger Touch (Fumoto) from Geno's. I modified it so all the oil drains out of the pan. Here are some pictures.<br><br>This is a drawing of the way the pan is constructed on my truck. <br><br><br><br>You want to drill these holes where the baffle is, so the oil can drain out through the baffles.<br><br><br><br>I am really pleased with this drain plug and would recommend it to everyone. It make changing oil just a flick of the lever! Just make sure you make the same modifications so all the oil drains out of the pan.
Old Jan 30, 2003 | 07:51 PM
GlennO's Avatar
I have been looking for a web page for Geno's, can some one give me the link to Geno's?<br>Thanks<br>GlennO
Old Jan 30, 2003 | 08:05 PM
jweir's Avatar
Here ya go...<br><br>Genos<br><br><br>Jim
Old Jan 31, 2003 | 09:21 AM
hanko's Avatar
[quote author=sixpack47 link=board=4;threadid=10195;start=0#97688 date=1043816812]<br>I also have the EZ Drain. ;D However I'm just waiting for my next oil change to install it! 8)<br>[/quote]<br><br>Torque per Femco is 40 ft-lb; you'll need a 1-3/16 or 30mm socket. Mine's been in for a year...works great.<br><br>-hanko
Old Jan 31, 2003 | 02:14 PM
Vaughn MacKenzie's Avatar
I have the E-Z Drain also which I like very much, but I wish you could drain the last quart of oil it keeps in the pan. I wanted to modify it like Big Bob did to his Fumoto, but that's not possible. . . the oil would just run right out of your pan open or closed <br><br>If you removed the EZ Drain to allow full drainage, the copper O-ring doesn't seem to be condusive to re-use. I've had trouble with mine leaking but Geno's replaced it for me.<br><br>Vaughn
Old Jan 31, 2003 | 05:35 PM
smokinjoe's Avatar
Ditto,<br><br>Got mine from Geno's and works fine!!<br><br><br> ;D ;D ;D<br><br>smokinjoe<br>ohio
Old Jan 31, 2003 | 11:56 PM
hanko's Avatar
[quote author=Vaughn MacKenzie link=board=4;threadid=10195;start=0#98924 date=1044044098]<br><br>If you removed the EZ Drain to allow full drainage, the copper O-ring doesn't seem to be condusive to re-use. I've had trouble with mine leaking but Geno's replaced it for me.<br><br>Vaughn<br>[/quote]<br><br>I've worked a lot of years on British cars and bikes. Copper washers can be reused by annealing the washer. Heat it red hot and drop into a can of water. Washer softens and is good as new.<br><br>-hanko
Old Feb 1, 2003 | 10:05 PM
sixpack47's Avatar
Big Bob, whats to stop a stick or rock from hitting the lever (for lack of a better desciption) and opening the valve and letting the oil drain out? ???. Is there a cap or something that goes on it to prevent disaster? I like the way you modified it to get all the oil out though ;D......
Old Feb 1, 2003 | 11:13 PM
Commatoze's Avatar
[quote author=sixpack47 link=board=4;threadid=10195;start=0#99485 date=1044158713]
[/quote]
I guess anything's possible, and if you used the truck offroad, the fingertouch may not be the best choice as it hangs down from the oil pan. The lever is spring loaded and is in a detent which prevents it from be actuated by accident. I had Fumoto valve on a 1986 Thunderbird Turbocoupe and it worked great the years I owned it, and I changed the oil in that thing every 2000 miles. There is no cap on the valve. The EZ-Change is very low profile and is capped except for draining.
