Does the compressor run....
Old Jan 16, 2011 | 03:26 PM
SILVER GUS's Avatar
I pet my truck from time to time....
....when the A/C button is off? I got a freon leak this summer and haven't gotten it fixed yet. So, I've been running the heat this winter with the a/c button off thinking it would be ok. Everytime I cut on/off the fan, I hear the engine load/unload like the compressor is kicking on/off just like when running the a/c. Am I hurting anything until I get the a/c fixed?
Old Jan 16, 2011 | 03:31 PM
tryNto's Avatar
When in Defrost mode the A/C is engaged, if it becomes too low on R-134a it will not engage the Compressor Clutch.
Old Jan 16, 2011 | 03:49 PM
SILVER GUS's Avatar
Ahh, forgot about defrost even though the a/c button is not engaged. Will it burn up something even running in defrost with no freon? Thanks.
Old Jan 16, 2011 | 04:09 PM
torquefan's Avatar
Yes it sure could. It'll have a low pressure switch that *should* prevent it from cycling with low refrigerant, but for peace of mind you might want to just disconnect the connector on the clutch.
Old Jan 17, 2011 | 08:01 AM
1-2-3's Avatar
Just a plain ole guy
It will cycle on and try to pump for a short time, then cycle off and repeat till you turn it off of defrost. it's best to unplug the power from the clutch.
Old Jan 17, 2011 | 11:00 PM
SILVER GUS's Avatar
Thanks. Are we talking just a plug/harness attached to the compressor somewhere? Just one or any others? Haven't crawled under yet to see.
Old Jan 18, 2011 | 08:12 AM
1-2-3's Avatar
There's a plug for the compressor clutch. Pull that.
WhoCares79
Jun 3, 2008 11:45 AM
Camarogenius
Jun 25, 2007 08:55 PM
Ramdriver15
Oct 2, 2006 06:28 PM
JKM
Mar 8, 2006 03:23 AM
