Code P0700
Old Jan 24, 2006 | 06:14 PM
kully560's Avatar
Code P0700
THIS JUST CAME UP TODAY P0700 DO i NEED TO BRING IT INTO THE DEALER OR IS IT NOTHING
Old Jan 24, 2006 | 06:26 PM
walt_mink's Avatar
P0700 is Transmission Control System (MIL Request)
I think that means that there is a problem on the transmission's computer and you need to have a scan tool hooked up to read it. Good luck!
Old Jan 24, 2006 | 09:16 PM
tcb's Avatar
tcb
are you by chance running a juice box. when i installed mine i got the same code. i think the tap on fuse 50 trans control is the reason. mine is running like always, just fine, but maybe the different ohm reading trips the code.
tim
Old Jan 25, 2006 | 04:19 AM
kully560's Avatar
no motor is stock no aftermarket
Old Dec 22, 2010 | 03:32 PM
JR0923's Avatar
I have the same code showing on my truck 03 that's not even close to stock. I'm in the same boat not knowing what to do! I'm going to try and unhook battery to reset the truck n computers hopefully that works
Old Dec 22, 2010 | 06:46 PM
SpeedyWS6's Avatar
P0700 means there are transmission fault codes stored. You will need a scanner that will display transmission data and trouble codes.
Old Dec 22, 2010 | 08:07 PM
JJPage's Avatar
This is correct, here is a link to a list of tranny codes, scroll down to 700 codes:
http://dodgeforum.com/forum/diy-do-i...4rt10ohio.html
zzsdad
Nov 6, 2004 03:53 PM
silverramer
15
Mar 12, 2004 08:04 AM
mitchkim
Feb 11, 2004 09:33 PM
DF5152
Feb 10, 2004 10:33 PM
