CB mounts
Old Oct 24, 2005 | 10:11 AM
whitebuffalo's Avatar
CB mounts
any of y'all running CBs in your 3rd gen? if so, how/where did you mount it? preferably stick shift ideas.......
Old Oct 24, 2005 | 10:28 AM
WL.'s Avatar
WL.
Cobra 29
I mounted mine under the steering wheel, more toward the radio. There is a fellow on here who was making brackets to mount them on the floor, kinda between the shifter and the seat.
Old Oct 24, 2005 | 12:24 PM
RamWheelsBy4's Avatar
Do a search on Big Bob CB mounts. This is mine, it will work with manual shifter I am pretty sure.
Old Oct 24, 2005 | 12:57 PM
SkyHarborCowboy's Avatar
How do you route the antenna wiring and which antennas are the best?
Joe
PS. RamWheelsBy4, who makes that gauge mount? How did you route the wiring?
Old Oct 24, 2005 | 06:40 PM
Ok I will answer that, and expect to be admonished by the "Real" CBers. I have had a CB in every truck I have ever owned since 1972. I used a Midland Window mount. Ran the antenna cable under back pillar and under door seals, then under carpet through opening for power seat wiring and to the CB. This antenna and the previous window mount worked fine for my needs on the road.
This gallery at DTW has pics of my CB install.
http://dodgetruckworld.tenmagazines....42-album-16979
Old Oct 24, 2005 | 07:07 PM
W.F.O.'s Avatar
Wilson antennas are unbeatable, i've wasted a lot of money to prove it!
Old Oct 24, 2005 | 07:18 PM
HorseHauler's Avatar
I love my setup, peaked and tuned uniden with wilson 1000 mag mount. sometime i would like to do dual 4' firestiks in the stake pockets on the bed rails but want to make sure it will perform as good or better than my wilson... i think i have a pic in my gallery of my cb. Edit- DTR made the pics to small, can't see em
Old Oct 24, 2005 | 07:38 PM
W.F.O.'s Avatar
Like i said i've wasted a lot of money, better keep what u got, just my 2 cents.
Old Oct 25, 2005 | 09:32 AM
JHardwick's Avatar
From what I've read, you can't get duals far enough apart on a pickup to perform properly.
I'm looking at the Cobra 29, but haven't decided on an antenna.
Has anybody cut the cubby hole bigger and mounted there?
Old Oct 25, 2005 | 10:22 AM
PsRumors's Avatar
There is no room behind the cubby hole. It is 5 or so inches deep so anything else on the radio would be sitting out from the dash.
Old Oct 25, 2005 | 03:08 PM
PsRumors's Avatar
OK, I got pictures and here is what I did.
I used a Wilson 1000 roof mount so the cable is under the headliner and brought down the back pillar between the right rear door and rear window. It then follows the door channel and comes into the compartment under the center front seat.
The radio is then mounted to the bottom side of the seat for the center section. I wanted something out of site as I drive to Atlanta and park where vehicles are known to get broke into. I plan on adding an external speaker I just haven't decided where. You can still hear the radio with the section closed.
There is a mic extension cable that plugs into a connector mounted in the front of the center section plastic box (under the center seat)
This enables the mic to be outside the center bottom storage area and everything closed up. The mic is out of the way when not needed.
Also while I was doing it I set an auxilary fuse block with 4 switched and 3 hot 20 amp circuits for running misc other items. It is fed straight from the battery and is keyed.
Just how I did it. Hope it all makes since.
Old Oct 25, 2005 | 03:40 PM
Buffalo's Avatar
CB Mount
As primitive as it may sound, I just mounted my radios to the sides of the transmission hump. Drilled a couple of holes trhough the carpet & screwed the mounting brackets to the hump. It works. Nowhere near a clever as the seat storage compartment mount. That one is really neat!!!
Be sure, before you drill, that there is nothing on the inside (transmission side) of the hump.
I, also, agree that there is nothing I have found that works as well as the Wilson 1000 antenna. I have the roof mount. Requires drilling the roof but, it's there forever. I've had magnetic mounts & they occassionaly get knocked off the roof by low hanging branches, etc. If you choose the roof mount & have the side air bags, be careful where you put the cable.
Joe F.(Buffalo)
Old Oct 25, 2005 | 03:47 PM
Buffalo's Avatar
Big Bob's CB Mount
I believe I heard that Big Bob's mount will not work with a six speed stick shift. I believe the radio sits right where the drink holders are. The shifter doesn't look like it would interfere with the radio unless the radio was really long.
Joe F.(Buffalo)
Old Oct 25, 2005 | 03:58 PM
Joe F.(Buffalo)
he has some that do work with manual transmissions and manual transfer cases...
Old Oct 26, 2005 | 01:55 AM
Big Bob's Avatar
Joe F.(Buffalo)
I'm sorry you are incorrect. They work fine.
