Cb
I mounted mine on the knee bolster under the steering colum on the right side. The antennas look good mounted inside the front two bed pockets. there is a large enough hole in the pocket to easily slide the wires through without drilling anything. I just fabbed up a piece of small angle iron with two nuts welded on the back side and inserted two bolts from inside the bed to secure it. Good luck
Im also looking for ideas to mount a CB in my 6 spd truck.. Ive looked at big bobs mount that mounts to the middle seat up front, but I carry six passengers fairly often, and see that mount as being in the way.
Scott
Scott
i was thinking of mounting mine on the floorboard by the 4wd shifter and mounting the antenna in the middle of the bed right behind the rear windshield.... or if i get a tool box on the middle rear of the box
chris
chris
I have my superstar mounted to the drivers side of the four wheel drive shifter housing. It works great as long as someone short doesn't have to drive all the time. I didn't think of that when I put mine there and when my wife drives she has to be careful how far up to move the seat. It doesn't get in the way mounted there. My antennais mounted to the front of the bed in the center of the rear window, but I can't make up my mind if I want to leave it there. It all works great. Don't have any pictures yet, still trying to figure out how to get them on here. Good luck.
Has anybody tried the glass mount antennas I will be putting a hard cover on the box so I won't be able to use it to mount the antenna and I don't like the magnet mount because they leave a mark in the paint after it has been on for a while
Re: Cb
Originally posted by Shepherd57
Any ideas on where to mount a Cobra 29 in the cab and where is the best place to mount the antena. I had it on the front fender on my 99 but the mount won't work on the 03
For questions, pm or email me.
Just my .02c, your results may vary
~Rob
I have a Midland Window mount that works fine for my needs. Had one on my last truck and worked well enough on long trips.
Some info from earlier post on TDR and link to that thread.
SWR Readings with new SWR Meter. I took these twice, because I didnt really believe them. Not bad for a $19 Window mount and a 16 year old Radio Shack TRC-484.
Channel 1 SWR 1.7 Transmit Power 2.8
Channel 19 SWR 1.5 Transmit Power 3.5
Channel 40 SWR 1.7 Transmit Power 2.9
TDR thread
http://www.turbodieselregister.com/f...5&page=1&pp=15
TDR thread
Re: Re: Re: Cb
Originally posted by MadMaXXX
where did you get that gauge pod????
Scott
Click on the link, about 3/4 page down are pictures of how i mounted my CB on the pasenger side of the hump, does'nt get in the way at all.click here
Rick
Rick
