A/C Question
A/C Question
I noticed yesterday that my a/c would start slowing down and then stop running. i would play with the control **** and it would come back on but would not blow consistantly with the level that i had it set on. does this mean that the blower motor is out or that the switch is messed up? the a/c blows very cold all the time so i'm pretty sure there's no problems with the system itself. thanks for any help.
You need an amp gauge , to see how many amps its pulling , if not over rated then look at the stepping resistor , one of the coils may be burning out .
Also look for stuff getting into airbox , I've seen things that fall through dash end up getting into air passages .
thanks, a friend of mine suggested to check the refrigerant level first then go from there. so i figure i'd give that a try and then start working back towards the more expensive parts lol. thanks for the reply though, it dang sure gives me a starting point if the levels are correct.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
