A/C Problem
A/C Problem
I apologize if this has been covered before, but I've searched the forums and I can't come up with something that has exactly these symptoms. Plus what I have read only confuses me on what it might be.
Here are the symptoms:
A/C works fine until I've been on the highway at least 45 minutes to an hour. The symptoms will not appear of the truck is just idling. The dealer let it idle for 2 hours and the symptom did not appear. I've also driven at slower speeds for extended periods without the problem appearing.
What happens is that the cold air coming out the vent will slowly reduce until it is just a "trickle." The air is cold and the fan makes the same amount of noise, but the air flow through the vents is severely reduced.
I can resolve this problem by turning off the A/C compressor (turning off the "snowflake" button, but not touching the fan or vent control *****). After about 30 seconds to a minute, the air flow increases to its normal amount. I'll then turn the compressor back on (again, touching only the "snowflake" button). The A/C and air flow will work normally for about 20 or 30 minutes, then the air flow will restrict again and I'll turn the compressor off and it will increase.
I've read some of the "blend door" discussions and I can't tell if that's the problem here. Any help would be appreciated.
Sounds like to me the AC evaporator is freezing up. Is the AC set to recirc when this happens? If so turn off the recirc and allow warmer outside air to flow through the evaporator core.
Also the freon can be on the low side which can also cause the freezing issue.
MikeyB
MikeyB
MikeyB
MikeyB
I had the dealer check the freon (more than once) and they said it was fine. That was their first response, as well. Maybe I should get another opinion?
Thanks for your quick reply...
https://www.dieseltruckresource.com/...ght=ice+sensor
MikeyB
Don't think there was a TSB on this. Only a memo.
https://www.dieseltruckresource.com/...tor+fin+sensor
MikeyB
MikeyB
My 03 did exactly that- freeze up the condenser.
The dealer moved the temp probe, but if it was 100+ and humid it would still do it sometimes.
Setting it on recirculate helps. I think once the moisture from the air in the cab has condensed (and probably frozen) it then doesn't build up additional ice.
Also make sure the drain tube on the firewall is clear and not clogged by a clump of mould or anything.
The fan motor is held in with 3 screws, and you can just drop it down and unlock and unhook it's connector. Next time it happens, you could do that and look to see if the condensor is frozen and/or plug the fan back in and turn it on to verify it is working (since the noise is the same I bet it is).
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
