Bulb replacement on climate control knobs 2006
Old May 3, 2010 | 06:40 PM
Reelay's Avatar
Bulb replacement on climate control ***** 2006
I have a 2006 quad cab ram, the ***** that light up behind the fan, ac, and heat control are burned out. How do you get into the back of the bezel to replace the bulbs. Looks like you might have to pull the *****, but before I do that, I would like to know if anyone has done this and how hard of a job it is. Thanks in advance. Ray
Old May 3, 2010 | 09:02 PM
pwrstrkr's Avatar
you just pull the dash out as if you are pulling out the stereo. There are 3 little bulbs in there and they unscrew. BUT according to two dodge dealers I've talked to and multiple parts stores, the bulbs are not a serviceable item and no one could find them for me. They said you need to buy a whole new climate control piece for about $100. kind of ridiculous but it seems to be the only option
Old May 3, 2010 | 09:29 PM
dieseloutlaw1's Avatar
I know mine is an 05, but my dealer says the computer showed one bulb for the climate control piece. $2.20 for one bulb, i'm also going to be replacing the instrument panel bulbs this weekend. I'll try to take pics and post them up..
Old May 4, 2010 | 07:14 AM
Reelay's Avatar
Thanks for the info guys, Outlaw, looking forward to your pictures. I hope the bulbs are replacable but you never know until you get in there. I will also try and find a tech manual at the local parts house. Thanks..Ray
Old May 4, 2010 | 07:30 AM
bettamsw's Avatar
You can order led bulbs from the internet that will replace the standard bulbs in the panel. When you pull the surround for the radio, the heater control comes with, then there are 3 bulbs that are just 1/4 turn, Make sure to get white led, the other colors don't work as well. GO to superbrightled.com and look there, I believe that they are NEO5x-w but not sure, you can check the deminsions when you pull out the old ones.
Old May 4, 2010 | 02:38 PM
Reelay's Avatar
Thanks very much for the reply, I will be doing this bulb replace this weekend. Thanks again!
Old May 4, 2010 | 03:17 PM
d zul's Avatar
On my 03 the bulbs are soildered in the board, probably different on yours. Check this link out, done this to mine and it looks great.
http://www.cumminsforum.com/forum/3r...tallation.html
Old May 4, 2010 | 04:03 PM
Reelay's Avatar
Nice pictures, I only want to replace the contol ***** they are burned out I believe. So with a little luck maybe I can "Get Er Done"! Thanks for your feed back and good pictures. Ray
Old May 4, 2010 | 06:39 PM
bigjohn04's Avatar
I think they are the same bulbs as my 04. Part #1-05013815AA
https://www.dieseltruckresource.com/...t-t259494.html
Old May 4, 2010 | 07:51 PM
Reelay's Avatar
Does anyone have any pictures or instructions on how to remove the contol unit? The pictures I have seen are after they are out not a break down of how to remove. I don't want to ruin anything in the process. I haven't found any screws to remove or any hidden tabs to push. Thanks.
Old May 4, 2010 | 10:48 PM
pwrstrkr's Avatar
reelay, those bulbs look like the right ones. maybe I'll just get some of them from dodge and try em out. thanks!
Old May 7, 2010 | 03:59 PM
paparcl's Avatar
Hey bro! at your age you shouldn't be driving at night anyway. Stay at home and leave the night driving to us "younger guys"
Old May 7, 2010 | 08:33 PM
Reelay's Avatar
Hey little bro you are probably right but these younger guys on here sure know more than I do about these new fangle dangle trucks. I'm use to unscrewing a screw and getting to the porblem now half the problem is how to get to the problem. As far as night driving is concerned I just like to sit in the rig at night in the shop and pretend that I am driving at night helps to see the heater controls you know how my blood doesn't circulate as well as it use too.
Old May 7, 2010 | 10:11 PM
pwrstrkr's Avatar
those 04 bulbs look exactly the same as the ones that came outta my 07. guess I'll try those.
hot rod al
Sep 10, 2012 10:30 AM
VPI
Feb 20, 2011 08:18 AM
robert78.5
Sep 28, 2007 10:23 PM
SolarYellow05
Jun 22, 2006 04:55 PM
grizzly660fan
Jan 2, 2004 10:02 AM
