Blower motor
Old Jun 21, 2008 | 06:14 PM
bighornrmk's Avatar
Blower motor
The blower motor only works on high. I've got the controls out of the dash. When I use a jumper wire to run fan, still only get high to work. Could it be the resister block for the blower motor. If so, is it located next to the blower motor.
Old Jun 21, 2008 | 11:51 PM
bmoeller's Avatar
Could be the speed control switch, resistor set (usually attached to the blower housing somewhere to get airflow across them to keep them cool), or a fuse.
I don't think the Ram does (I don't think, but could be wrong), there are some vehicles that use 2 fuses for the fan. 1 fuse controls the lower fan speed settings, and the other controls the higher fan settings.
Old Jun 22, 2008 | 12:12 AM
Spooler's Avatar
If it only works on high then it is the resistor set that should be on the blower motor housing after the fan and before the heater core / evaporator.
Old Jun 22, 2008 | 08:16 AM
03RAM2500's Avatar
99.9% sure it is your resistor since you blower is working on high. The resistor cost me about $70.00 here at my local dealer.
Old Jun 22, 2008 | 08:33 AM
bmoeller's Avatar
I had a fan switch fail before, and it only worked on Hi. Ne resistor set didn't solve the problem.
Old Jun 22, 2008 | 09:46 AM
03RAM2500's Avatar
The 3rd gen trucks (at least my 03 model) dont have two fuses to control fan speed. The the fan/blower will have a constant +/- 12.6v power supply to it when the ignition switch is turned on. The resistor is linked into this power supply and controls the fan/blower speed. If you have a buddy close by to try his resistor, I bet this will solve your problem. It only takes a few minutes to change -2 screws and a quick disconnect plug.
Old Jun 22, 2008 | 09:47 PM
bighornrmk's Avatar
Thanks for the quick responses.
Jim Lane
Apr 5, 2020 06:03 AM
RedRocket
May 21, 2004 01:28 PM
Jones0027
13
Dec 18, 2003 01:10 PM
Copenhagenjunkie
Jun 1, 2003 04:20 PM
