Leaf in blower motor?
Old Dec 16, 2003 | 07:43 AM
Jones0027's Avatar
Diesel Gods,
Here's a good one... Lately when I turn on the heater, the blower motor has a growling sound to it. ??? Took in into the dealer(still under warranty) and they found a leaf in the blower motor area??? Isn't that funny? Anyway, they removed the leaf and everything is fine. Love my Cummins. 8) Adios.
Old Dec 16, 2003 | 08:58 AM
MnTom's Avatar
Re:Leaf in blower motor?
That has got to be one of the most annoying sounds there are.
Old Dec 16, 2003 | 09:38 AM
PHX_ATC's Avatar
You gotta have shade in Mexico when they make them. How else are they gonna stay cool? ;D ;D
Old Dec 16, 2003 | 12:41 PM
Diesel Dave's Avatar
At least it wasn't a mouse nest. When you turn on the fan, that can get ugly real quick!
Old Dec 16, 2003 | 02:00 PM
Helicopter Dan's Avatar
the fresh air filter Geno's sells will help keep leafs out of there, and bounce dryer sheets placed in the truck are supposed to keep mice away especially if you have your truck parked for awhile. just a fyi
Old Dec 16, 2003 | 02:02 PM
Rattletrap1's Avatar
Try this:
In my Ford a few leaves ended up in the little box the blowermotor draws from. It had a small circuit board that was some type of current limiter. The leaves shorted out the board and started a small fire in the box. Filled the cab with smoke several times before I diagnosed it.
Old Dec 16, 2003 | 02:04 PM
that would be bad Rattletrap1 lucky the truck didn't burn up
Old Dec 16, 2003 | 05:39 PM
DPG's Avatar
DPG
I used to regularly take the blower box apart on my GMC and my Ford to remove leaves. So far, not my CTD!
Old Dec 16, 2003 | 06:05 PM
Fillerupsonny's Avatar
I had a pine needle in my blower a couple of days ago, was driving me crazy. Just took the three screws holding the squirrel cage housing out, dropped the cage down and pulled out the needle. Just took about three minutes start to finish.
Old Dec 16, 2003 | 08:29 PM
KC Super 80's Avatar
I checked out the Geno's air filter setup for the blower, but I thought it might be too restrictive and there other paths that the air could follow to the blower and not be filtered.
I installed stainless steel screen over the opennings in front of the windshield under the black plastic cover and sealed off the other areas. ;D
My .02
Old Dec 16, 2003 | 08:47 PM
LHartman's Avatar
I gotta jerk the blower motor in mine. Sounds like a rattlesnake in there everytime I fire up the blower. Any trick to this other than removing the bolts?
Loren
Old Dec 17, 2003 | 09:09 AM
Dieseldude4x4's Avatar
Mine has one in it too. Just waiting for it to dry up enough for the fan to grind it up and blow it out the vents.
Old Dec 17, 2003 | 06:40 PM
infidel's Avatar
[quote author=KC Super 80 link=board=5;threadid=23807;start=0#msg224779 date=1071628149]
My .02
[/quote]My concern was that the Cab Fresh filter would be restrictive also but no way. I'm using a Scotty Air Unit, the air for the intake passes though the Cab Fresh as well as vent air with no problem.
Not sure how any cab air could get past it.
Another advantage of the Cab Fresh is that it's easier to brush snow off than the stock setup.
Old Dec 18, 2003 | 01:10 PM
infidel,
It's good to hear that the Geno's isn't restrictive. I did the mods. to my truck at least a year ago, so I can't remember all the litttle places I put screen material. The two larger opennings I can remember are the water drains on either side. It's easy to find the other ones when you take the black plastic cover off and feel around in there.
Jim Lane
Apr 5, 2020 06:03 AM
TJE
Mar 28, 2011 08:38 AM
Patrick Campbell
Nov 28, 2007 04:39 PM
Joe T
16
Jun 12, 2007 12:11 AM
Palmetto_kid
Apr 10, 2004 01:26 AM
