battery cable ends
Old May 25, 2009 | 11:51 AM
tndiesel's Avatar
battery cable ends
One of my battery cable ends that attaches to the battery terminal needs replaced. It's on the battery that is on the passenger side. I need to replace the bolt also. Can I get this at most parts stores and anything special I need to know?
Thanks
Old May 25, 2009 | 01:27 PM
TAS05CTD610's Avatar
You can, what I like to do, and what others have done, is go to home depot / lowes, ect, and get a brass end cap (like for ground rods, ect) Then heat it with a torch, fill it with lead (solder) and get it as a liquid. Leave around 1/3 of the space empty and push the wire into it (and hold it) This will form a much better connection since it's 100% connected vrs only the outside wires conducting electricity like on the "clamp" type replacements. I've done this in the past, and it works a lot better. Used to have cranking issues with the clamp style, but once I did the solder issue, it cranked much better.
triker888
Dec 12, 2010 10:13 AM
traverler48
15
Oct 28, 2010 12:37 PM
tchdodg
Jul 28, 2010 01:45 PM
Underpsi
Feb 23, 2007 10:18 AM
Mr. Jimmy
Nov 18, 2005 08:41 AM
