Battery cable ends
Old Jul 28, 2010 | 08:59 AM
tchdodg's Avatar
Battery cable ends
I need to replace my battery cable ends, but none of the auto shops seem to have heavy duty enough ones, ones that are big enough to hold all the wires that go to the ground side of these truck's batteries. Where do you all find yours? My local NAPA has some that have a stud on top that I could put terminals on the small black wires then bolt to the top, but I'm not sure I trust these. What do you all use?
Old Jul 28, 2010 | 09:34 AM
Sea:\>Drive's Avatar
Search locally for a welding supplier. They'll have lugs that you can solder on the end of the wires - or crimp (but you need a BIG crimper)!!!
Old Jul 28, 2010 | 12:22 PM
BigGreen's Avatar
If they are just fitting loose autozone and advance auto also have little caps that slid onto the batteries. They just make the posts bigger and allow the cables to tighten down. I had to use these and have never had any problems.
Old Jul 28, 2010 | 12:27 PM
tchdodg's Avatar
The problem isn't fitting on the post, it's securing all 3 black wires into the cable end. There is the big black cable, then 2 little wires that go into the cable end also. The problem is keeping all 3 of them secured so they don't work loose and lose contact.
Old Jul 28, 2010 | 12:38 PM
BigGreen's Avatar
Ok then those won't work for you. Have you thought about just removing the bolt and putting eyelets on the ends and putting between the nut head and cable end.
Old Jul 28, 2010 | 01:21 PM
Junk Man's Avatar
http://custombatterycables.com/appli.../dodge_ram.htm
Old Jul 28, 2010 | 01:36 PM
DIESELWRKS's Avatar
why can napa order them I did on mine. next day had the new heads the where not the crimp style they where the 2 bolt clamping style work great. and like 4-5 bucks
Old Jul 28, 2010 | 01:45 PM
tchdodg's Avatar
You sir are a genius. No, I hadn't thought of that, but the way today is going, I need someone to point out the obvious. Thanks.
triker888
Dec 12, 2010 10:13 AM
traverler48
15
Oct 28, 2010 12:37 PM
tndiesel
May 25, 2009 01:27 PM
Underpsi
Feb 23, 2007 10:18 AM
Mr. Jimmy
Nov 18, 2005 08:41 AM
