Alarm going off at all times.
Guest
Posts: n/a
My Ram sometimes honks it's horn in alarm mode when I open the doors after unlocking with the fob. The alarm then goes on and I'm unable to turn it off for about 15 seconds, very bad when it does this at 6am.
I'm wondering if this can occur if I open the door too soon after unlocking. I'm think I'm not pressing the panic button without noticing, if I was doing that I'd be able to turn the alarm off instantly, wouldn't I?
Any way to disable this alarm for good?
Guest
Posts: n/a
The only security system is the original thing and I'm trying to locate the connection between the system and the horn, without disconnecting the horn from steering wheel.
I have sometimes set my horn off too when unlocking the doors with the key fob. However, I have never had a problem with shutting it off once it goes off. I just press the lock and unlock button again. I also thought, that I was opening the door to quickly and the truck Sentry System did not process the unlock command yet. So, I just live with it. I am wondering if It has to do with the fact that I have the truck set to open all the doors with a single unlock command instead of two. Another thought is maybe the battery in the remote is going out since it only has just started and I have never had to change my batteries yet.
Have you tried to unlock your door manually and see if it still does it?
Shawn
Shawn
Guest
Posts: n/a
I also have the doors unlocking with a single command. Maybe this has something to do with it. This really isn't a big problem and happens perhaps once a month (and always early morning or late night...), so opening the doors manually isn't telling much.
Maybe I should slow down and allow few seconds from pressing the fob to opening the doors.
