Adjusting Headlight Aim
Old Dec 18, 2007 | 12:00 PM
dieselkan's Avatar
Has anyone adjusted the aim on their headlights. My headlights are about right with no load - maybe abit on the high side. But with the fifth wheel RV hitched up the headlights are way to high and I get alot of flashing from on coming cars. Is there an easy way to adjust them?
Old Dec 18, 2007 | 12:19 PM
RowJ's Avatar
I often have same problem. Here is my method....
Find a wall......... park on level ground, 25 feet away. Put/pick a level line 5" high on the wall.
Both lights should be just below that line (at 25') and just inside straight ahead, as determined by sighting down the side of your truck!
Works well and obviously, works best at night. I have a perminent line marked on side of my garage for when I'm making a long trip.
RJ
Old Dec 18, 2007 | 01:06 PM
dieselkan's Avatar
Where is the adjustment screw on the headlight? The owners manual doesn't have any info and I can't see anything on the headlight assembly that looks like it would adjust the aim.
Old Dec 18, 2007 | 01:14 PM
ptgarcia's Avatar
When looking from the front with the hood open, near the inside edge of the headlight their is a hole behind the rubber seal about midway up the side of the light with a Torx head adjuster in it. Turn one way to adjust up, turn the other way to adjust down.
Old Dec 18, 2007 | 02:03 PM
dieselkan's Avatar
Thanks alot. I'll look for it.
Old Dec 18, 2007 | 08:28 PM
eodshawn's Avatar
Yes thanks I am getting tired of being high beamed all the time!( people thinking my high beams are on)
Old Dec 18, 2007 | 10:54 PM
snoyes's Avatar
Also you may want to look at a set of airbags to help with the headlight aim issue when loaded. Seemed to help me out alot when I slap the trailer on there, just air the bags up and don't have to keep adjusting the headlights...
Old Dec 20, 2007 | 06:50 AM
skindaddy's Avatar
5inches or 5 feet high?
Old Dec 20, 2007 | 07:48 AM
RowJ's Avatar
OOOOOPS!
Good catch! Probably no answer required!
RJ
Old Dec 20, 2007 | 10:43 AM
dieselkan's Avatar
Wouldn't 5 feet be too high? Thats probably where mine are now.
Old Dec 20, 2007 | 11:13 AM
RowJ's Avatar
Maybe. Was working from memory.The idea is to have the headlights just below level at 25'!
Best would be to measure from level ground to center of your lights.... and make your "line on the wall" at that height!
This would solve the problem for lifted and leveled trucks as well!
RJ
Old Dec 20, 2007 | 11:19 AM
ptgarcia's Avatar
I think what you want to do is mark a line 5" below the level line from the headlights and hit that at 25' out.
Old Dec 24, 2007 | 11:15 AM
alaskaflyer's Avatar
I just parked my truck 25' from my garage when it was stock, made a mark then adjusted the headlights to that mark after I installed the lift. 5" below level sounds right to me.
Old Dec 24, 2007 | 11:30 AM
skindaddy's Avatar
my lights from left to right seem to shine both ditches real well
high beam seams quite high comp[ared to low like middle of trees
TxDiesel007
Aug 22, 2005 09:24 AM
iker42
Aug 20, 2005 11:43 PM
ramlovingvet
Jun 19, 2005 08:43 AM
joel
Mar 13, 2005 07:32 PM
OR4ster
Mar 17, 2004 02:41 AM
