6 speed question
Old Feb 4, 2011 | 10:01 PM
weatherman's Avatar
6 speed question
I have a 6 speed in my 04 3500. I have noticed that over the last year that i've had the truck that it is harder to get it into gear. I am thinking the slave cylinder might be going bad. Anyone have this problem or have any insight on this? Thanks
Old Feb 4, 2011 | 10:14 PM
rockcrawler304's Avatar
How many miles? Original clutch?
Old Feb 4, 2011 | 10:19 PM
FMB's Avatar
FMB
Pretty easy to replace. You purchase the Master and Slave as a connected unit and install it without taking it apart. No Bleed. Where are you at in this world? I have a new set in the garage.
Old Feb 4, 2011 | 10:44 PM
weatherman's Avatar
101,000 miles... and yes i believe its the oringinal clutch
Old Feb 4, 2011 | 10:45 PM
weatherman's Avatar
What do you want for it?
Old Feb 4, 2011 | 11:33 PM
FMB's Avatar
FMB
I'm not good at shipping stuff, hoping you are close to Sac.
Old Feb 5, 2011 | 09:41 PM
C Schomer's Avatar
I change the lube when mine gets to shifting stiff. Craig
Old Feb 5, 2011 | 09:54 PM
weatherman's Avatar
What do you usually use? Whats a good place to get it?
Old Feb 6, 2011 | 08:24 AM
MikeyB's Avatar
The NV5600 is particular on the type of fluid used. Popular choices would be Pennzoil Synchromesh Fluid, Amsoil MTF and Redline MTL. Mopar dealers will also have it and so does GM dealers (listed for the NV3500).
It's recommended to overfill by at least one quart to help lube the upper bearings. To get the extra fluid in you can fill via the top shifter cover or the top PTO bolt hole if you have a pump.
BTW, I'm running six quarts of Amsoil MTF.
MikeyB
Old Feb 8, 2011 | 06:20 PM
weatherman's Avatar
So where do you put in the lube? The transmission it's self?
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
