4x4 manual shifter removal
Old Jun 6, 2005 | 08:29 PM
drrv1's Avatar
I recently bought a used 2005 3500. The carpet in it was shot so I have decided to replace it. I have removed everything but the manual 4 wheel drive shifter located on the floor. Just curious if anyone knows how to remove it. I tried unscrewing the ball as well as lifting up on the housing that surrounds it. It doesnt seem to budge. Any ideas would be really appreciated.
Old Jun 6, 2005 | 08:52 PM
nickleinonen's Avatar
pop the plastic disc off the 4x4 shifter, then grab a 15mm socket and remove the nut from inside the ****.. then unscrew the ****... then you can remove the boot... the shift lever is bolted to the t-case linkage with a single screw...
pic of 4x4 shifter with floor console removed
Old Jun 7, 2005 | 10:37 AM
tobyw's Avatar
How in the H-E-double-hockey-sticks do you get the shift boot off, though???? I've pried with all of my might at every corner and all along the edges with zero luck
Old Jun 7, 2005 | 01:08 PM
there are some steel tabs that hold the bugger down... if i remember right, you need to pry up from the narrow ends [i think i started by the firewall end] and once you get your fingers under it, pull hard...
i grabbed a quick image out of the service manual... once it is approved, you can see it in my members photo gallery
if you want to see the service manual 2003 or 2004, you can google "hemi truck club", find their site, and on their main page, left side under the index, you can find links where you can preview the 03 or 04 service manuals... if they accidently get cache'd on your HD for off line viewing...
Old Jun 7, 2005 | 02:32 PM
tobyw's Avatar
Sweet
Double sweet
td3620
Feb 10, 2014 10:02 PM
HUNTINNUT
Jul 27, 2013 11:40 AM
tslewisz
May 13, 2008 03:34 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
