4.10 or 3.73 with 315 tires?
Old Feb 3, 2004 | 10:24 PM
coolhand's Avatar
Hello everyone
Thanks to all I just ordered a 2004.5 CTD 4x4 quad cab, after much reading my choice was clear. but only one prob I just cant stop thinking about the new truck
I have a question. whats better 4.10 or 3.73 rear with 315 tires?
Old Feb 4, 2004 | 12:29 AM
Matt400's Avatar
I think the 4.10 goes better with 315's. I have 285's with my 3.73's and its geared plenty tall with an auto trans. Also remember the Auto in OD is taller than 5th in a stick.
Old Feb 4, 2004 | 08:09 AM
rossn2's Avatar
I ordered the 315's yesterday and I have the 3.73 gears with a 6spd...so will see how they run in a week or so and let everyone know....I'll post pics too once installed.
Old Feb 4, 2004 | 11:33 AM
mjbarr99's Avatar
Go with the 4.10s which will give you about a 3.77 rear end ratio after installing the bigger tires. I have 315s and the 4.10s and I very happy with them.
Old Feb 4, 2004 | 11:55 AM
TexasZach's Avatar
mjbarr99... What would the final ratio be when running 285's with 3.73's? And also with the 4.10's?
Old Feb 4, 2004 | 01:37 PM
coolhand's Avatar
I was afrade of that. I wonder if it's too late to change my order
Old Feb 4, 2004 | 03:05 PM
diirk's Avatar
coolhand:
Are you getting the auto or 6spd. I've driven both, and the auto with 4.10 wasn't bad at all, and that was with the stock tires. It'll only get better with the 315's. If you're getting the 6 spd, I think the 3.73 would probably be a better bet.
Old Feb 4, 2004 | 04:29 PM
coolhand's Avatar
Diirk:
I ordered the auto w/3.73 rear.
just talked to DC about my order stat. they said my truck just got it's VIN # today and is ready to be assembled in mexico......so nop I can't change my order.
Old Feb 4, 2004 | 05:28 PM
mjbarr99's Avatar
285s with 3.73 gives a final ratio of 3.60
285s with 4.10 gives 3.96
Old Feb 4, 2004 | 10:06 PM
TexasZach's Avatar
mjbarr99....Many thanks for the help.
Old Feb 4, 2004 | 11:03 PM
RickE's Avatar
mjbarr99,
Are those numbers the equivalent to stock tires? If not, please explain how you get those ratios.
285s with 3.73 same as 3.60 with 265s?
Old Feb 4, 2004 | 11:09 PM
Matt400's Avatar
Here is a chart you can plug in the axle ratio, tire size you want to run and the speed you like to cruise at- press calculate and it will spit out the engine RPM's
Old Feb 5, 2004 | 10:58 AM
banshee's Avatar
With a 6 spd, I think 3.73s are the only way unless you're always pulling at or over max weight (like commando said). I sometimes hunt for 7th on the highway, and first is really too low unless you're towing. 2nd gear starts are about right in day to day traffic. For the auto, though, I would do only 4.10s. The auto's 2.45:1 1st gear is pretty low and needs the rear gear to help it out with big tires. You may get a bit of a flat spot off idle with the big tires and the 3.73s, but a fueling box should help that out a lot.
John
Old Feb 5, 2004 | 11:37 AM
rossn2's Avatar
315's came in last night, only 1 day UPS from Shreveport, and went down and had them mounted at on post AAFEES. This morning went to Dodge Dealer and had them set the "PINION FACTOR" for the 315's. The Revolutions per mile at 45mph is 601 for these tires and I have them set at 45psi all way round. I immediately noticed that when at 65mph tach is just under 1800, at 40-43mph tach is around 1100 rpm and engine is lugging a little, so I'll have to adjust and drop into 5th gear, which I did and it rev'd up to 1400-1500rpms. I noticed a little rub this morning going into a parking spot, but think it may be the tire hitting the mudflaps, that are mounted to the Bushwacker Street Flares. Yes, the nose is still down, but man these tires look sweet. I also noticed at atound 65mph I have a little steering wheel vibration/shimmy...it may be that the tires aren't warmed up yet (only 5-6 miles)..or not balanced correctly or tire pressure too high in frt. I'm heading south texas tomorrow and will run for 5-6 hours...so will see then how it responds and take back to tire shop for rebalance or new tire if needed. Gotta love that road hazard/balance/rotation warranty you can get through AAFEES...It was too dark and rainy last night to take pics...maybe try tonight before dark and post in my gallery...
oh the 2" leveling kit is just a spacer that fitson top of the front coil springs. You have to remove wheels, remove shocks, drop the coil spring out to install them. You may have to remove one of the swing arms to get the "A" arm to go low enough to get the coil out and back in...and you may or may not need an alignment afterwards, but just have it checked to be sure...No, I do not have the 2" leveling kit on at this time...Wife is ****** enough I bought new tires for a new truck
