285/70/17 vs 315/70/17 pros and cons
#31
If you want the best mileage you need to keep the revs below 2000 rpm. 2200 will burn way more fuel than 1600 -1800.
35's did not hurt my milage or power but I have a stick, actually it improved things for me on the highway, the stick's OD is a little on the low side from the factory.
#33
If you have mods that make more HP then larger tires will not effect much but I am at stock 235hp. Towing 8k at 60mph at about 1600-1700rpm in OD with 265's. You say adding an inch of tire diameter (285's)will have no effect?
#34
Anytime you lose gear (via taller tires) you lose power to the ground.
The question is: How much? Enough to notice given the type of driving you do?
I went from 33s to 35, have factory 3.73s.
Driving empty, not much of a difference in power, just slightly lower RPM.
Pulling 11K lbs., I do notice a slight loss of power. But still have enough to spare.
If I was pulling significantly more weight, I'd consider re-gearing.
If you have 235 hp, then you're going to notice the effect of gearing/tires more than guys with more powerful trucks.
RobV2500
02-01-2009 03:46 PM
jwb600
13
02-03-2008 10:53 PM
trx
22
08-14-2007 02:31 PM
SPINPOSI
08-24-2006 10:44 PM
Ironstone
04-25-2006 05:57 AM
