2500 to 3500 conversion
Old Jul 10, 2006 | 05:54 PM
SOhappy's Avatar
Anybody installed the extra OEM leaf spring(s?) for a 3500 in their 2500? Or is it better/cheaper to go with aftermarket overloads?
(hope this is the right forum, it's not really a performance & accessories topic since I'm mainly interesed in an OEM upgrade, right?)
Old Jul 10, 2006 | 07:19 PM
bigwheels94's Avatar
I put a set of air springs,& a sway bar on mine.Will ride smoother that way.Hauls my 3000* slide in camper with ease..
Old Jul 10, 2006 | 07:33 PM
C Schomer's Avatar
Ditto on the airbags and swaybar too, if you need one. Craig
Old Jul 10, 2006 | 08:54 PM
Jfaulkner's Avatar
Muted User
the problem is the overload spring bumpstops that are welded to the frame. I'm not sure if you could buy them from dodge, of course you could always make your own, or just use aftermarket springs. I used air bags and a leveling valve so it always rode at the same height reguardless of load.
Old Jul 11, 2006 | 04:34 PM
TopBanana's Avatar
j
it is possible to do this conversion, i did it on my truck. there are quite a few things that u need to consider and plan out in order to make this an easy swap.
with that said i would recommend using aftermarket airbags instead on 3500 overloads.
but, if u want to use the overloads just pm me i'll be happy to answer any questions u might have.
Old Jul 11, 2006 | 06:35 PM
SOhappy's Avatar
Thanks guys. Looking into Timbrens, seems like a cost effective easy way to go to essentially accomplish the same thing.
(Ok, so NOW it's an aftermarket thread!)
horselady
May 27, 2011 09:19 PM
redwake9112
Sep 3, 2007 11:35 AM
Mark Hodowanec
35
May 15, 2007 03:30 PM
dragginlx
15
Mar 9, 2007 11:32 AM
Dieselhead
May 13, 2003 03:50 PM
