2003 3500/2wd Tires cupping
Old Aug 24, 2007 | 10:12 AM
hdrhlr's Avatar
Unhappy 2003 3500/2wd Tires cupping
The front tires on my 2003 quad cab 3500/5.9 cummins start cupping (inside of tires) at about 4000 miles (I rotate every 4000 mi., 60 psi in 265/70-17 E rated). The guy that balances and aligns my truck says that it is in alignment and balance. This is a quad cab 2wd and it is lower in the front than it is in the back, could that be part of the problem, and would a leveling kit help. Any suggestions or comments out there. Thanks, HDRHLR
Old Aug 24, 2007 | 12:28 PM
gsbrockman's Avatar
You never indicated the exact mileage on your '03. I'd suspect worn or weak shocks or worn front end parts.
Greg
Old Aug 24, 2007 | 05:18 PM
Jeff in TD's Avatar
I'd second the shocks suggestion. My dad had a pickup that did the same thing, a 2wd Ford that cupped tires even though the alignment was within specs.
After removing the shocks, you could feel it resist normally except for about 1" of movement that it would blow right through w/o any resistance at all.
Anyhow, new shocks, no more cupping...
Old Aug 29, 2007 | 07:37 AM
hdrhlr's Avatar
Thanks Greg and Jeff, I will replace the shocks (whats the best shock on the market). Any thoughts on leveling kits (my truck is real low in the front). Thank You, HDRHLR
Old Aug 29, 2007 | 10:35 AM
ryclef331's Avatar
I flipped the spacers in the back of my 2wd 3500 to drop the back almost an inch and a half...it was kind of a pain but the result is same ride, lower stance for easier trailer hook up for what I tower and I'm not "fronting" like I got a 4wd...
Old Aug 29, 2007 | 02:19 PM
C Schomer's Avatar
My 97 (w/Wranglers) cupped on the front, nothing wrong with alignment or shocks. Put on Firestone exploder tires and no problems with them at all. Craig
Old Aug 29, 2007 | 04:03 PM
rodboy's Avatar
better check the ball joints.
Old Sep 1, 2007 | 08:40 PM
gofastman's Avatar
I also found out by running the max of 80 psi will make a difference on these tires....all i have run on my truck since brand new is michlins....and you can look at my sig an see i dont let the grass grow to much....but 80psi i can get righ at 95000 out of a set, if i lower it....which i did at first andf it dropped to 76000, so the pressure does make a difference
Old Sep 1, 2007 | 08:58 PM
ScienceOfSpeed's Avatar
i had the same problem, i had to replace my outter tie rod ends, u might wanna check
Old Sep 1, 2007 | 10:52 PM
stumpjumper's Avatar
shocks or ball joints cause cupping.........
sakisaki400
23
Dec 31, 2006 10:17 PM
Dynocon
Oct 30, 2005 06:59 AM
sherman
Jun 15, 2005 12:29 PM
belfert
18
Jul 27, 2004 05:25 AM
gdh11
Apr 7, 2004 01:18 PM
