19.5 inch wheel source
Old Nov 12, 2007 | 10:27 AM
nooska's Avatar
Where can I look for 19.5 inch wheels for my 3500 SRW truck??
I know of Rickson, Vision etc.
All I want are stock 19.5 inch wheels that I could sand up and paint, nothing fancy. Just a steel wheel.
Are there used vehicles that have this size wheel on them that would fit my hubs without any adapters etc.
I just want to carry more weight than my E range tires.
Thanks
Old Nov 12, 2007 | 11:41 AM
Vinceg99's Avatar
If you find a source I would be interested as well dont need anything fancy and even the steel wheel through Rickson are over $200 a piece.
Old Nov 12, 2007 | 05:38 PM
firemanram's Avatar
I have the American Eagle wheels & Hankook tires. Pics are in a thread titled 19.5 tires & wheels.
Old Nov 12, 2007 | 05:46 PM
JP-4.5's Avatar
When I was researching 19.5's for my rig I remember reading something about 8 lug chevy rims that may have worked. Not exactly sure but it may be worth doing some searching around. I think it may have been from Dually vans or cube vans maybe? Wish I had the links still but they have been long deleted. I decided on the Ricksons and ended my long search about 9 months ago.
The gearing the 19.5 tires worked out to is perfect for my typical travel. The tires I think will last a long time. If I come across the info I will make another post.
Old Nov 13, 2007 | 06:49 AM
Hounddog's Avatar
Bread truck.
Old Nov 13, 2007 | 10:18 AM
nooska's Avatar
OK on the bread truck.. Thanks
I was confused for a minute, bread truck = step van...
Thanks
Old Nov 13, 2007 | 10:43 AM
nooska's Avatar
I located a Chev P-30 1986 . He says he has spare wheels and tires.
Would these fit my hubs with no modifications.
Old Nov 13, 2007 | 02:33 PM
Hounddog's Avatar
There was a LOT of discussion about this a long while back.At least I think on this site if not it was TDR. I can picture the bread van and I don't think it was a P30 but I could be wrong.Have you tried doing a search? Think they fit from the jump street or maybe a lug nut issue that wasn't to hard to correct.
Old Nov 13, 2007 | 02:35 PM
haulin-rv's Avatar
Step vans are going to be dually style. Vision is going to be the least expensive out there. Heck you should be able to get 4 for about $800.
Old Nov 13, 2007 | 02:40 PM
Hounddog's Avatar
I found some threads on the bread truck wheels.Do a advance search and just use 19.5 in a decending to older threads.
Old Nov 13, 2007 | 04:16 PM
haulin-rv's Avatar
There was a guy at a dyno event I went to that did that, they are 8 on 6.5 but the center has to be machined since our trucks have a larger hub diameter. The real challenge is finder 6 that are straight and good. But again these do not apply to the original question since he has a srw and these are drw.
Old Nov 14, 2007 | 04:19 PM
G-NOTE's Avatar
Wink
These are the wheels I had on my last truck you can see it in my gallery they are direct bolt on...
HERES THE WHEELS:http://www.americanforcewheels.com/195.html
Flying Circus
Dec 15, 2009 11:51 PM
Sea01Cummer
Oct 21, 2005 09:52 PM
1Thom
15
Sep 23, 2003 03:05 PM
shaft
Sep 1, 2003 03:37 PM
bdaniel
May 6, 2003 04:43 PM
