'07 OEM Security
'07 OEM Security
Do any of you folks have the sequence of steps to take to lock your doors with the key fob (set security system on) while your truck is running with another key in the ignition to step into the convenience store for two minutes for example?
I could have swore I got it to do it once when I just picked it up, but i'll be darned if I can remember how now.
Everything I try isn't working.
I got it to do it once by mistake, but can't remember how.
All I have is the factory OEM security with keyless entry - whichever one that is. Key fob and key are all in the same package.
hmmm mine won't do that either!! last night after i picked it up from the dealer, i ran in for groceries, and i had to lock it with the other key , and it wouldn't unlock with the other fobb, i had to use the key to unlock it too.
(on the new 07)
(on the new 07)
I swear I did it once by chance, but you now how those go, one doesn't remember how.
There must be a way to defeat this so one can lock all the time.
Lock
Finally tried mine. It works. Started her up and locked the doors with the other fob. Horn sounded and she locked. Unlocked when I pushed unlock on fob.
Makes no sense!
Hmmm
Oh yes, myself and SRTchris have already disovered this. Now, after doing the unlock thing, go for a drive (around the block even), et out of the truck and try locking with the other fob again. Unless we're missing something, you'll see that it won't do again it until you shut down the truck, set your security on (lock the doors), then unlock, start truck - only then will you be able to lock while running again.
Makes no sense!
Makes no sense!
