06 aux. back-up light wiring
Old Apr 14, 2006 | 10:03 AM
belltech64's Avatar
I have searched for aux. back up lights. What wire did you, who have added back up lights, use to trigger the relay. I'm having a tough time deciding what wire to use. Thanks.
Old Apr 14, 2006 | 09:44 PM
SR53's Avatar
I just used the wire @ 7 pin trailer jack. I used some cheapo wal-mart lights, alot better now
Old Apr 14, 2006 | 11:07 PM
torquefan's Avatar
I think it's purple, but don't quote me.
Old Apr 14, 2006 | 11:10 PM
GOTMEAT's Avatar
I always wire my lights on a seperate circuit so I can use them in Park and Neutral as well.
Also works for tailgaters as well.
Old Apr 19, 2006 | 04:30 PM
zapata's Avatar
Please. Can someone elaborate more about "How-to" do this..??
Old Apr 19, 2006 | 05:03 PM
GOTMEAT's Avatar
If you can follow this diagam, it's really simple. Just hit the switch when you want them on.
Old Apr 20, 2006 | 06:15 AM
Hercules130's Avatar
what kind of relay is that? can i get it at radio shack?
Old Apr 20, 2006 | 08:52 AM
nickleinonen's Avatar
that is just a plain ol relay. most automotive relays have 5 pins on them. if you get one with 2 pins marked 87 and not 87 & 87a, then it is just like that above relay but with 2x outlet normally open terminals. if you get an 87/87a, one terminal is normally open [NO] and one set is normally closed [NC] in that type, you would just use the NO terminal and wire like above [and stick a blank covered 1/4" female blade on the NC pin]
http://www.the12volt.com/relays/relays.asp <= a good read on relays for those who are not totally understanding them
jkravito
Oct 11, 2006 09:32 PM
Txwelder
Dec 26, 2005 08:45 AM
JoshPeters
Apr 3, 2005 08:13 AM
Blast54
Nov 2, 2003 01:46 AM
