Brakes and Alignment
Old Apr 14, 2006 | 09:48 AM
jka's Avatar
jka
Truck had a slight pull to the right when I picked it up from the dealer about a month ago. (bought it used). I called them back they said no problem they would do an alignment. Got the alignment done drove it home and it had a left hand pull that increased when the brakes were applied.....weird. I let them know and will be taking it back to get it checked.
Last night we had to go out of town and I noticed a squeel, not a loud one, every once in a while when the brakes were applied. At one intersection in town at about 35 mph. I put the brakes on and the drivers side front wheel locked up.
What do you think? The truck only has 22,000 kms. on it.
Old Apr 14, 2006 | 10:34 AM
John Faughn's Avatar
Its early for rusted slides for the caliper , but do they use salt on the roads there?
Then its possible that someone put the wrong fluid in the brake res. , look and see , its not real early to flush the brake system , and look at the fluid ,
next is also early , but every so often a flap of rubber on the inside of the brake hose will rip and acked like a check valve ,
Just some possibles.
Old Apr 14, 2006 | 01:00 PM
jka's Avatar
jka
Salt is used.
Maybe that's all it is.
Old Apr 20, 2006 | 09:52 AM
WSA308's Avatar
There is absolutely no reason that one front wheel should lock up. The squeek I can see as a result of a dust film on the rotor when you come to a stop after traveling in dusty or high grit conditions. The lockup may be a result of malfunctioning ABS sensor or improper bleeding of the break on setup. Do you notice any inconsistant wear on one of the front tires.
njmaier
Jun 18, 2006 06:50 PM
wildcargo
Nov 29, 2005 04:20 AM
IsItFast
Nov 14, 2005 12:47 AM
smokeyram
Feb 15, 2005 12:02 PM
ron717
Feb 25, 2004 12:35 PM
