03 3500 LB Duelly electric windows
The passenger and rear windows will not work from those doors (Window Lock in NOT SET). I keep hitting the window lock button and the windows will not work at either setting most of the time.
I can control them from drivers panel but they only work intermittently at the other three doors....any particular area to look for the problem???
i have the exact same problem on my truck, some people said replace the switch and another said check the harness running under your door kick panel. good luck and if i find anything else i will let you know. still diagnosing mine
I had a bad wire between the door and the door post on drivers side rear door. The dealership mehanic took one look at the booster seat in the back and asked if I had seen my kids pulling on the harnes, seems he had come across this before. The kids will pull on black wire harness to pull themselves up in the truck and stretch the wires till they pull apart inside the cover. He had to splice in two new wires.
Replace d.rivers side window switch
Wifes 03 Durango and my 03 ram had the exact same issue.Hers started it first and then mine.Same part # for Durango and Ram.Replaced both at same time.4-months ago,no problems since.$114.00 a piece.
Rednecktastic
Nov 15, 2010 09:29 PM
slenglis
Oct 18, 2009 06:47 PM
markster
Oct 7, 2006 02:20 PM
